Ultra Simple Class D
Norazmi thanx i did use 22uh 47 turns with the red core 1uf filter still have this problem coil heats up ill post my ee & ei ferrite cores smaller than ei33 maybe you can help me calculate
hehehe i want to experiment the core every core have different response red core good detail audio,green good for low ,
what about this one gap is bigger than the other one
This is original schema, credit goes to the owner ejtagle from forosdeelectronica, as u wish u can always make your own design for the pcb, in class D make it as compact as possible, note that this module stable within maximum voltage is +/- 50vdc and do not go more than that voltage unless u`re experience in class D for component adjustment. bd139 and bd140 will provide heat, if more than its maximum voltage it might be burn. so please follow the maximum voltage with the component listed on schematic.
p/s - see attachment. original compress as .rar and i rename it to .zip, you can rename it back to .rar
best regards,
Azmi
pwm with EE core
update outputs are warm coil not heating up good result loud and clear output filters used 2 uf idle current 8mv dc
