Select the jFETs by Idss as recommended. That's all you have to do.
Well, not quite.
I would accurately measure all the resistors and select to ~0.1%, both between upper and lower and between channels.
This makes for reliable current measuring later, if there are problems to be corrected.
Well, not quite.
I have setup the front end of my recently completed (well very nearly) F5 monoblocks according to what EUVL has suggested here: http://www.diyaudio.com/forums/pass-labs/121228-f5-power-amplifier-869.html#post2277700
I used the Toshibas (K1530,J201) on the output but didn't concern myself with any sort of matching there.
who are the suitors then?
the dog will let me know, and it won't be good for them!
Hello,
I've not been able to find or to understand an explanation to the need of matching transistors in the original F5 amplifier.
Within a single channel, I "extrapolate" from various diyaudio threads that P and N MOSFETs don't need to be matched (also because they are technically different). But what about the JFETs?
I also "extrapolate" that matching MOSFETs and JFETs between left and right channel is not necessary (probably it's useful if I want to do the same operations to bias the two channels, but I'm not sure about it).
Any help is really appreciated 🙂
To operate, there is really no requirement that the parts be matched. I like them all matched, simply because I want both channels to match as close as possible. It just depends on how obsessive you want to be....
russellc
If the parts are mismatched, couldn't some of the discrepancy be compensated for in the bias settings? If a sensitive dB meter was used? Notwithstanding the minimal difference in distortion between channels. ?
Ron
Ron
Turbo? Sounds good 🙂I see you left room for F5 Turbo parts.
The text will be done in a few days - you will see it next week.
If that means more power - same quality, i guess it will be a choice for my second amp, as i am plannig to drift to two-way active system cofiguration.
Best regards.
D.
Is the schematics of the F5 Turbo released by Papa ? I heard about it 2 months ago on this forum but I have been very busy since then...
And a note to those who have been waiting patiently, I'm about 10 days
from releasing the F5 Turbo Kraken.
I think, with a little luck... the F5-T will be released this week 😀
Jesper.
Well I don't think so, I know for sure !!
When it's ready, Choky (Zen Mod) and I will get it from Choky's Papa (Mr. Pass) and we'll build and test it within a few hours and after that it'll be presented to you all 😀
Just hold on there and you'll be rewarded with the fantastic turbo sound for DIYérs
Audiofanatic 😉
Jesper.
Audiofanatic 😉
Choky's
Last thing i heard, he had a Santa boot collision experience at the SR front gate when he started to wave adoption papers.
http://www.diyaudio.com/forums/pass...high-end-off-topic-thread-28.html#post2265611
Choky is better thatn me
I won it two times in one day, the reason was, a T-shirt was stocked in the input of that turbo, which I didn't know 😀😀
Audiofanatic 😉
naah ....... I'm forbidden to mess with turbo
last time when I had it , I won Pike's Peak 3 times in one day
Audiofanatic 😉
I need to listen to this thread.
Maybe a supercharged F5 is just the thing for my hotrodded DCB1 ?
Let' s wait and see. If it has more gain that F5...
- F5 power amplifier
