switch
try this site too: Illuminated Vandal Resistant switches - IP66 sealing - by Bulgin ComponentsDanger Mouse, nice! love it!. Can i ask where did you buy the front
power push button?, i am looking for a similar power switch...
Those ones are really nice but 50ma @ 24 volts!!!. I'd like to skip the relay approach, wanna keep it KISS...
Well I've finally added a B1 to the Aleph 4 - What a WONDERFUL combination.
In its initial guise it supported a 15VA EI transformer and a capacitive Multiplier with MKS caps throughout.
It grew up very quickly and supported a 30VA toroid with substantial CRC PSU. This dropped the CM. The B1 also then got modded with Siemens MKP caps at the input and Obligatto PIOs at the output.
RESULT - MUSICAL NIRVANA.
My Pass F5!!
very good amplifier!
some pics:
another pics at
Pass F5
Now i need a new good preamplifier on the same level...
Bye!
some pics:
another pics at
Pass F5
Bye!
Great stuff. Excellent work.
Heartiest congradulations.
Why not show us the inside as well ?
Schönen Gruß,
Patrick
Schönen Gruß,
Patrick
Thanks, you can find what you want in the correct thread, here http://www.diyaudio.com/forums/pass-labs/86300-ugs-adventures.html
Martin
Martin
Martin, there are commercial manufacturers who couldn't make things that nice if they tried! Congratulations on a stunning project!!! 😀 😀 😀
Having seen all of the thread, I have to say this is the perfect reading for anyone exploring the potential of diy...
Congratulations everybody!
this looks like a little piece of l'art to me
I am reffering to post #999 by merlin2069er and to his jfet boz
Thanks!
I thought I had posted the complete jfet boz. Anyways, here it is...
Nice one. Metalwork looks like modushop.biz. Where did you get the front and backplate surface done?
Hi Holger,
the chassis is a 3U 400mm deep from modushop, correct.
The front and backplate design is made by myself and machined by Schaeffer AG in Berlin.
I assume you sent the original Modushop front and back plate to Schaeffer?
I was wondering if you can get those galvanized corner profiles, to bolt the case together, separatly?
Walter
Walter
Walter
Hi Walter,
Schaeffer machined the original plates from modushop, yes.
About the corner profiles, i would ask them. 😉
- Pictures of your diy Pass amplifier
