Dear Sir
hello please will this circuit protect my hf please help me and tell if my pcb wrong
thanking you
sameerx1
Pcb is OK, use heatsinks for IRFs and increase value of 2k2 resistor to 2k7 or 3k3 for smal HF drivers.
mile,
how many watts this x-over limiter can handle
post#66
1200W, but with 2 inch HF driver
and this x-over,
will this work w/o changes with h900 amp
This x-over is for 1 inch HF driver use with 500W amp
what changes do i have to make for this x-over to work with h900
This protect don't compress peaks.
It just clips them. Won't that 10 watt resistor go smoke if you run the thing continuously in protect? DJs have been known to do that. I'd beef it up to a pair of 20 watters in parallel - and don't forget to heat sink the power transistor.
Yes resistor must be 40W if power is continuously double than maximum (25V RMS on driver), I forget protect from DJs
Apex sir,
about 3D
please share some more details.
Details in post #22
- Live Sound
- PA Systems
- DIY PA Speakers Setup (Line Array)
