I have one great sounding Buffalo II and using spdif input directly connected to my Squeezebox Touch. Squeezebox has not a transformer on the spdif output. I would like to isolate galvanically the coax spdif connection.
How should i do it ? Anybody can give me a hint ?
I suppose one circuit composed of one small transformer, cap and resistor will be enough.
For the new Buffalo III there is one "Single S/PDIF Level Converter Kit" for 29$ and is using the TTL level input. B II has TTL level input.
Any advices ? 🙂
Any advices ? 🙂
Thanks Brian.
I was confusing the S/PDIF Transceiver Module with the Single S/PDIF level converter kit.
On a seperate note, I work in e-commerce. IMHO, put bluntly: Unless the buying process for this kit has been deliberately designed to put off individuals who lack the ability to decide and purchase the necessary items for their requirements; more kits would be sold if the buying process was simplified.
Any advices ? 🙂
You could use the single level converter with the B-II (connected to D1), and turn off the S/PDIF switch.
DSD Output from SACD Transport to Buffalo III DAC
I am going to build a Buffalo III DAC to direct DSD output directly from a SACD Transport to the Buffalo III DAC. However, it appears that you cannot output DSD directly from a SACD and that S/PDIF will not handle this level of data output. Is this the case? Is there another type of connection (i.e., HDMI) that is required?
Kris
Kris
You need to tap the DSD signals from inside the player, before they are encrypted for HDMI..
Denon DVD-1920 mod - Project Gallery - Twisted Pear Audio Support
Denon DVD-1920 modding - Buffalo DAC - Twisted Pear Audio Support
Denon DVD-1920 DSD output to buffalo - Buffalo DAC - Twisted Pear Audio Support
Single S/PDIF bIII input
using Single S/PDIF board, do i keep jumpers on the input of bIII, or use
input remaping?
input remaping?
input remaping?
You use only the analog (output) jumpers.
Leave all of the input jumpers off. No need to set remapping.
The DAC itself is a 32bit DAC, and if you want to take full advantage of that then you need to use PCM or DSD data.
In order to use the full potential of 32bit, the analog section should have SNR of 192dB – as of today, impossible achievement.
Yikes - theoretical optimal 32bit analog signals and taking full advantage of an existing 32bit DAC are two completely things. 🙂
The fact remains you can only take the very best advantage of this actual (not theoretical) ES9018 32bit DAC using PCM or DSD data.
You can get into with ESS about whether they should call it 32bit or not. Not my battle. 🙂
It's no one's battle. My comment intended only to point out that I see no pratical benefit in 32bit over 24bit.
GLT/Russ
I now have the B-III board and am setting up the jumpers, please confirm if the following approach will result in the "B-II way" of wiring the B-III, such that I can connect either I2S and DSD (with input re-mapping "on").
JDSD1 and JDSD2 in place, plus, a wire jumper from D2 (or the input pad for JPCM1) to JDSD1. And no jumpers on JPCM 1-3. This would result in:
D1 to data1 and data 5
D2 to data 2, data 4 & data 6
I am pretty sure I understand, but I would like confirmation before soldering. And thanks, for all of your help!
That's the BII wiring configuration:
http://hifiduino.files.wordpress.com/2011/08/biiinputmap.jpg
And then you apply the input remapping switch for BIII
There are many real/practical benefits in using the 9018 over competing DAC chips currently in production.
And yes there are number games that matter but you have to look deeper than the "32bit" tag and the whole "32bit VS 24bit" debate...
I'm well aware of the benefit of 9018 over competing DAC chips. It doesn't change the fact that due to the analog section's SNR limitation, there aren't more than 24 effective bits.
How do you input the DSD output into the Buffalo III? What wires connect to the Buffalo III?
Kris
Kris
Look in the intergration guide...
D1: DSD R channel data
D2: DSD L channel data
DCK: bit clock
G: Ground
I do not know how multi channel hooks up off the top of my head.
Kris
DCK: bit clock
G: Ground
Found the answer on the Twisted Pair Audio Board:
DVD-1920 DSD -> Buffalo
BCK (Pin 37) -> DCK
DSD1 (Pin 38) -> D1
DSD2 (Pin 39) -> D2
G (Pad CS52) -> G
DVD-1920 PCM -> Buffalo
PBCK (Pin 50) -> DCK
PLRCK (Pin 51) -> D1
PDATA1 (Pin 46) -> D2
G (Pad CS52) -> G
BCK (Pin 37) -> DCK
DSD1 (Pin 38) -> D1
DSD2 (Pin 39) -> D2
G (Pad CS52) -> G
G (Pad CS52) -> G
When running wires from the BIII to the IVY boards, should I be using shielded cable? I'm not sure if this is important or not. Are there chances of crosstalk/picking up hum from the transformers? Is this also relevant for the lengths from the IVY boards to the physical output jacks that would go on the outside of the case?
The best solution is to stack using the included mezzanine connectors.
Russ...
Can you confirm if I understand the above correctly? I have the B-III on my bench, and am ready to finish it up. Thanks.
- More Vendors...
- Twisted Pear
- Buffalo III - flexibility without compromise.
