You must wire it in B3SE mode. Joining D1 to D5 and joining D2 to D4,D6. You could do this with the jumpers or with plain wire at the inputs - your choice. Then you must set the DIP switch to operate in stereo mode (switch 2 position 8).
Thank you, Russ.
I prefer to join them by jumpers. And SE mode.
So am I correct if understand that I should USE all jumpers?
JPCM1 (JPCM1, 3)
JPCM2 (JPCM2, 1)
JPCM3 (JPCM3, 2)
JDSD1 (JDSD1, 5)
JDSD2 (JDSD2, 4)
Then active Input remapping by SW2 position 8.
I just posted a nice case with display and microcontroller over in the Swap Meet forum for the Buffalo III DAC. There are optional modules too.
Hi Russ, Brian
Finally I could achieve my target to run both DSD and PCM by connecting just JPCM1,2 and JDSD1,2.
DSD and PCM file sound smoothly without pop,click but very low volume. Normally, my amplifier is in 12h position, now I have to turn it to max position, but it is still far from normal sound level.
I am using IVYIII and notice that Buffalo III volume port doesn't work, same level at any operation.
Anything wrong or just normal because jumper changing so I have to increase gain in IVYIII?
Many of you will be interested in this:
http://www.diyaudio.com/forums/twis...ffalo-iii-se-pro-9028-9038-a.html#post5212726
Cheers!
Russ
Cheers!
Russ
Cheers!
Russ
Oh yes! Already ordered.
uFLs are pre mounted , Yes???
I mangled them the last time.
Hmm - I think I might have just made it private for now - I will move it over and make it publicHi Russ, as the github links to the latest non-pro BIII firmware do not work anymore, can you please make it available either on the existing github or the documents section in the TPA site?
Thank you very much.
It also needs a rewrite...
Stupid Question...
Bought a Buffalo III from a guy here at the forum... Seems to be an older one with an old firmware from 2012..... How can I update this firmware?
You can order new firmware from the site if you like. But you may not need to.
- More Vendors...
- Twisted Pear
- Buffalo III - flexibility without compromise.
