If you don't need the gain since you make do with a dcb1, choose #144 which is a follower that Scott Gregory makes. The gain circuit you posted is right too, but we use an active regulator for B+ since then for both common cathode or cathode follower. Either Maida, or SSHV shunt reg (smoother).
I was gooing to try as a pre after wonderful DCB1 as volume control. Planned on using you regultors of course. May need current source on top for gain since it will be driving power buffer. Do you have proper incarnation of regulator forthis amp. I know you offered two. Happy new year.
Gives 15dB gain with the resistor, if its enough to your speakers. Just a little more with CCS load for the additional work and devices. No real boost. Would need careful suspension and placement to avoid microphonics when in gain mode. Use straight profile 6V6 bottle. Look for SSHV2. I would make double mono regs set at 45mA each.
Use a grid stopper 220R-1K attached to the 6V6 control grid pin if you will use just DCB1 and interconnect instead of 6V6's own vol pot. Also 0.1-1Meg resistor from stopper's input end to ground.
Was it a pro sound compressor machine?
yes, this and many versions over the years, AM864 was one of the first vari-mu as this one is modeled off of. Manley vari-mu is simular. The La-2a was based off of this design. The detection circuit was modified to drive the tb4 module instead of backing off the bias of the first stage.
90% of my circuits I build go into the music world
Salas, being new to tubes, i realized that tubes need heaters, i think. What kind of filament supply do you use on this thing.
I was looking at tent labs module and from the digram it seems to be a shunt regulator. THe 317 is a series regulator, correct. I am headed out of town, so i will haev time for research.
Buzzforb,
You will not go wrong building this with AC as the heater supply. Later you can modify it to go DC if you find necessary. I doubt you will have any issue.
Shunt regulators need quite a bit of heat sinking for filament applications. If you feel DC is critical then use a CCS for to regulate the filament current.
For this pre amp spend your effort on the circuit and making sure that the tube is mechanically suspended to minimize vibration. You will reap many rewards doing that first.
Thanks SGregory, I was just looking at Rod Coleman heater supply. There is a guy on amazon offering matched quads of JJ 6v6 tubes. Do you think this is safe as I have a credit I would like to use it. Tube depot is the only other source I have found. Why the carbon film resistors vs metal film?
Since there is not a lot of components to this thing, any advantage conically to high end resistors like TF020 or other fancy types. I don't know how much I believe this sort of thing and experimenting can get expensive. Ill look up the tungsol.
Naah, brown Dale for gate stopper, cathode, and shunts, Mills for high power anode load and you are sorted.
Rod's heaters are aimed at direct heated tubes. For an indirectly heated tube such as the 6V6. Both the Tentlabs and Rod Coleman heaters are absolute overkill.I was just looking at Rod Coleman heater supply
Could you post a pic please?
- Tubes / Valves
- 6V6 line preamp
