Hi guys
This thread is a place to put images, ramblings and other such bits into some that will loosely resemble an attempt to document the latest(and largest) design from me to date. This is truly a statement speaker standing a statuesque 205cm tall with a considerable 75cm depth and utilising no less than 9 drivers per side. I live to build speakers like this 😀
A quick note to say these are being built for a forum member here - Ackcheng. Many thanks to him for his suggestion to share all this here. Arthurs initial goal was simple - take the LGT and add a separate subwoofer tower to each side to increase the low end. Whilst that would have worked fine it did seem like a missed opportunity to create something significantly better and so came about the Apollo.
Details
In a nutshell the Apollo is a 4way design borrowing heavily from the LGT but with improvements made on every level.
I particularly wanted to address the large center to center spacing of the LGT which was caused by the lengthy RAAL 140-15 ribbon tweeter and to a lesser extent, cabinet design considerations. This has now been greatly reduced by using the much shorter RAAL 70-20XR and tightening up the cabinets. The end result allows for a tighter MTM arrangement.
Other improvements include 5" drivers utilising a midrange specific surround profile along with custom designed 8" to give maximum impact in the mid bass region.
Perhaps the biggest departure from the LGT is the inclusion of four Audiotechnology 10" subs with Sandwich Cone which will give a cone area well in excess of an 18" driver. No doubt the low frequency extension and impact will be considerable! These 10" drivers are arranged in an opposing push-push arrangement, two in the top and two in the bottom cabinets. By directly coupling the mounting arrangements on each driver it'll take full advantage of Newtons third law causing the forces from each driver to cancel.
Drivers and layout are as follows:
S = 2x 10" AT Flexunit 10F 77 25 10 KAP
W = 8" AT Flexunit (model to be decided)
M = 5" AT C-Quenze 15H 52 06 13 SDKAM
T = RAAL 70-20XR
With preliminary crossover points at 60-80hz, 300-350hz and 2.5Khz.
Other small details include the use of Cerabase Classic.
Construction
The cabinet are to be constructed from MDF and Corian. Various combinations and laminations of 18mm and 9mm MDF will be used for the cabinets. And 84mm(7x12mm) thick Corian for the baffles. Corian was chosen for its ideal damping and stiffness properties that will create an excellent mounting point for drivers working from 80hz and upwards. Unfortunately its expensive and so moisture resistant(aka Extira) MDF will be used for the cabinet sections.
As the project progress construction details will be revealed in greater detail.
Finishing will be gloss black cabinet portions with polished corian baffles(kind of like polished marble)
Expectations
Since this is a close relative to the LGT its typical to expect a similar sound but refined even further and with more capable extension. 15hz-40Khz will be the bandwidth of this speaker and I can't imagine there being anything in the way of compression even at beyond reference levels. This is going to be one crazy pair of speakers.
The fun doesn't end when the project is completed either because they're being shipped from the UK all the way over to HK. The shipping crate construction will be almost as involved as the speakers themselves 😀
For now its early stage renders but I'll be pressing ahead at full speed with these in January. The overall size and shape is determined but a detailed model is in the works so between now and January there'll be more renders as its fleshed out.
Apollo vs. Aurora and LGT.
Details
T = RAAL 70-20XR
Construction
Expectations
As always, inspiring and amazing. How you get all those angles to work without industrial quality machining I will never know.
Cant wait to see the final outcome and best wishes on the build.
Maybe when you are finished we can get a build price to consider
You sure don't do things by half Shin! Looks like it's going to be a truly reference standard speaker.
I joined because I couldn't stand not being able to see the pictures of your latest design. I really love your aesthetic sensibilities.
So since you are using the Raal 70-20xr, I take it you now have some sort of a formal speaker company? I know you had talked about that somewhat in an earlier thread.
Hi Shin,
I always work to minimize the M-T-M physical spacing to reduce lobbing, and even cut off portions of the faceplate on a small diameter tweeter like the SB29RDCN toward this min-separation goal.
Have you considered a different modularity strategy with separate Woofer cabinets and separate MTM cabinets that can be stacked to create several different configurations and room multi-woofer placement options? This might provide both superior sound and a more flexible product line.
Thanks George.
Eventually that's the intention eventually but for now I seem to have work enough to occupy virtually all my spare time and so this is a distant goal but something I'm working towards non the less.
LineSource is right Shin. A modular design like this would not only fill a gap in the market but also be achieveable with minimum compromise using a pc xover. Commercial may be a thought for the future, but going the modular route gets the initial R&D costs out the way while it's still a hobby & you could bring start with the MTM & bring the other parts to market at your own pace. Sub contract the manufacturing & concentrate on fit, finnish & setup.
Looks brilliant as always.
Hi Linesource and Tim,
Thanks for the suggestions. The modular route is something I've played around with in the past and will no doubt do so again in the future.
This particular project is pretty much bespoke but for the more realistically sized speakers its definitely worth looking at again. Its a good challenge to get all the individual components within a modular system designed well on all levels and both with each other and as separates. Once you've found that however I agree its very appealing.
If your not up to the challenge, I can always arrange for some tea-chests to be shipped over to you to make a modular system more within your reach!!
Even then 'damping' the cabinets might prove slightly problematic.
You may not have seen shins previous builds- he's up to the challenge 😉
Hi Shinobiwan,
As much as I admire your work, I would take the separate subs advice to heart.
Impressive as the speakers physically and hardware-wise are, in sub-bass they are -as most integrated high enders- rather fighting the room than melting into it.
Welti and others have shown the way.
Good luck.
Eelco
Good luck.
Eelco
Hi Shinobiwan,
Good luck.
Eelco
You have a point there. If I were our man Shin, I would consider using several sub locations, on both sides of the enclosure, spread out in both height and panel location, per tower. By distributing their locations around, and having 2 towers, he could distribute the bass source location a fair bit and gain much of the "multisub" benefit. One push-push pair at floor level, one 30% up, one 60% up (6 woofers per tower... oontz oontz oontz!)
Hi Shinobiwan... that is some serious pair of speakers! I really like your choice of drivers and materials... A true SOTA project
I know that the design is more or less frozen at this time so I will not dear to propose any changes 😀
But anyway, have you concidered using constrianed layer damping (visco elastic glue) and vibration dampening of the driver chassises?
br, and good look with the project!
Hi Shinobiwan,
Good luck.
Eelco
Hi Eelco
Thanks for your post.
I can see where your coming from but these are in better position than the usual cabinet with a single driver mounted a foot or two above the ground. You've got that and you've got another closer to the ceiling and then that driver array is mirrored on the other side of the cabinet. Add to that another cabinet for stereo and you've got eight subs located in in different position across the front of the room.
The type of problem your talking about will always only be addressed with separate subs at the sides and rear of the room and that's beyond the scope of a stereo pair and moving more into room acoustics analysis and problem solving. Its possible to add subs to this to achieve this of course.
Hi Tytte and thanks.
The drivers have magnet braces which will calm that sort of thing. AT drivers are well built and solid too.
There's no constrained layer approach but I do use 9mm + 18mm laminations for the walls and then further line the interior walls with 2mm lead sheet and 2mm bitumen. This along with fairly extensive bracing gives a significantly resonant free cabinet.
The baffles are Corian which is basically a composite of 1/3 acrylic mixed with 2/3 bauksite and then heated together. Its a superb material for loudspeaker applications but is expensive and difficult to machine.
Sounds like a safe bet! You know my address Tim 😀
- Apollo Construction Diary
