Offtopic discussion split off:
http://www.diyaudio.com/forums/full-range/201423-adding-colour-driver.html
Sonido SFR200 in labyrynth enclosure, channel of the TL is designed to be triangular (no parallel wall resonanses).
labyrinth -looks like BLHorn? good thing
Hi all.
On the big 12" speaker did anyone else?
50-15000 Hz, 100 watts, sensitivity 97db
Design - transmission line with an exponential cut to half the entire length.
In this design has made a powerful impact at low frequencies
I I did not do the above - the family does not understand.
yes.., it would look somewhate strange and ugly)
here´s another familiar project,still being fine tuned,the famous Viech,with modified Beyma 8ag/n.
I´ve been trying to sort some problems with the midbass,but somehow,I´m always enchanted by it´s sound quality,considering the build´s price tag.
I´m completely hooked on full range speakers and from now on,it´ll be the only way to go for me!
So and I
And my Sonidos
I used two old woolen blankets.It looks like you covered the inside surfaces with carpet. How many surfaces did you cover & how much by the speaker?
For every loudspeaker - just one blanket, without the rest
Even inside band synthetic fur. (leopard).
Might need synthepon, filling to 1/3 the length of the tube.
These I had not seen beforeSo and I
- Full Range
- Full Range Speaker Photo Gallery
