I have up graded some parts with (I hope) better ones available on local suppliers. It is hard to find audio grade parts in my small city (I live in Solo-central Java).
I use some nichicon caps, wima, and sanyo.
If I have no mistake, I have a better low, mid and high now. Much punchy bass ...Crisp high and clearer mid.
I use a snubber PSU with 4X 10.000 uf/63 V. It needs larger heat sink. This amp uses temporary casing until does not up grade again. So interesting amplifier.
With regulated PSU maybe it will sound better.
My skill is poor, so I don't know about any measurements. I will leave it to the expertise.
Again thank you Mr Mile S. I do appreciate your advices for making this amp getting better.
Warmest Regards,
Arif B
Do you use any protect on this amp?
5532 seems an odd choice for a DC servo.
Why?
Why an inverting DC servo followed by an inverter?
Could a non-inverting servo do an equally good job?
Why?
Why?
Why?
Why?
Why?
Yes, non-inverting single OP can be use, but I like old 'marantz SM6'...
Hello sir, Mje 340 and 350 without heatsink, is it ok? Should i add small heatsink for mje?
Thank you.
Thank you.
Thank you.
It's OK, MJEs work in class A with 6mA, but you can add small heatsink.
Not yet, I have an old speaker protector, can I use it? Or should I build new one. I have your protect schematic already. If it is a must I will try to build one. I really need your advice.
Thank you in advance.
Best Regards,
Arif
thank you sir for your reply. God bless You
Best Regards,
Arif
You can use it, any protect will be better than nothing,
To Sir Apex.
Sir good days to you...can you share pcb with AX17S...? thankking you in advance
tnx...benny
tnx...benny
AX17S
Thank you for this pcb design.
Just a simple contribution.
Hi Apex,AX17S V2 pcb
What is the difference with AX17 for the sound,
is this one has a deeper bass?
I'm not make the AX17's PCB yet, maybe its better a lot AX17S
or better I make the AX17 first & add servo latter?
Hi Apex,
Amplifier must be neutral in sound, for deeper bass use speakers with deeper bass or 'loudness' circuit if you must.
No need to use servo, match transistors and add pot for set DC offset, with DC servo it's easyer (auto set).
Hi Mr APEX, i dont understand the utility of the pair Q3/Q5 (Q6/Q8) instead of only one transistor.... can you explain me?
Q3/Q5 are used for 1mA CCS, Q7/Q8 are used for cascode circuit.
- 100W Ultimate Fidelity Amplifier
