SSLV1.1 builds & fairy tales
Merlin,
I'm sure if you look around the web you'll find an estimate of the current needs the 0404 has. There are many posts over at head-fi, you could check the manual or directly ask Creative/EMU tech support.
I would disable it's power hungry features like the 48V phantom supplies.
diyAudio Chief Moderator
Joined 2002
1. Polarity 4 wires connection checked: was correct.
2. shunt reg 2.7A it's enough device max power consumption 1A see attached pic of wall psu supplied with the E-MU
Don't know why you get problems, if its something in the set up that is wrong and you don't spot wrong. But don't use the 9610 at 2.7A, its out of spec. Set 1.25A CCS and be sure the 9610 is still working.
Joined 2009
E-MU 0404/USB with BiB working OK, thank you Nick:).
I left the output lytic BG 47uF 160V VK series & resistor jumped or I have to come back to MKP 10uF 63V & 1R resistor?
Joined 2009
Some pics just for fun:)
Joined 2009
Merlin,
Thanks for support, there is a switch on/off for the 48V panthom supply, see pics.;)
Nice. Avoided sinks by using the chassis also, is it cool enough for the power levels you set? Did the bib benefit listening with your DAC?
They stay nice and cool though I'm only running them at approx. 200ma.In comparison with another sample of the same DAC using lm7812/7912's it definately does improve sound quality.The biggest difference to me is in the areas of dynamics and bass depth and slam.
