Oh snap my negative 12 volt reg. is now sitting at -26 and will not adjust down with the pot.A quick check showed neither the IRF610(Q201)nor MJE15030(Q206)appear shorted.Any guidance as to where to start looking?
Look if Q201,206 show few volts between their G,S pins each. For 206 BJT look for ~0.6V between B,E.
P.S Check BC560 for 0.6V between B,E also.
-5.5v between Q,S on Q201 nothing between B,E of Q206 and only about 0.13v between B,E of BC560.Look if Q201,206 show few volts between their G,S pins each. For 206 BJT look for ~0.6V between B,E.
Change 560, test, then Q201.
Finally i've finished my first BiB....
It will supply a v-dac II.
output 14v
R101 2.7ohm + 3 green leds
Voltage across resistor is 0.90 v
for circa 0.340 ma...
is it good?
I'm using a 18v 60va transformer
output 14v
is it good?
output 14v
is it good?
mA or A?
How many current draws v-dac II?
sorry 300ma!
i think it draws about 200 / 250 ma...
i've measured with the tester non more than 200ma for about 30 minutes...
i think my setting would be fine...
what you think about?
Left 100mA more of headroom: 350mA
Current don't change with time, only change the voltage with time.
Cari saluti
Cari saluti
Cari saluti
Do you think i should change the r101 value?
Yes, if you want to increase the current.
Pic's will welcome.
What kind of cap are you using in the Vref?
Pic's will welcome.
Thanks ,I don't have any spare BC560's but I have some BC556's so will drop one in and test.Change 560, test, then Q201.
Its time for the output BJT. Shows no Vbe voltage ~0.6V?
OK ,and correct 0 vbe.
- Power Supplies
- SSLV1.1 builds & fairy tales
