Iron Core Transformer Formula
from the available winding area, i allow 80% for copper, 20% for insulation materials....
then from the 80% percent, i allot half of that for primary and the other half for the secondary.....
you choose your wire size this way....even if your formula tells you to use gage 14 say, if space permits, nothing stops you from using #13....
if you can not get the desired wire size fit into the window, then you use the next bigger core size.....
equations are fine, they are mere guides as to how to proceed with traffo buildup....design is iterative process....
bottomline, whatever figure that comes out of the formula does not mean you have to stick to it, it never happens that way in the real world.....
That is simply not true.
There are professional software programs providing you with a complete winding scheme (number of turns, gauges, interleaving thickness a.s.o) given a particular core size and voltage/current requirements, and these programs are accurate (transformers are physical things; you can calculate everything).
I have seen this in the "real world", just a pity that I can't afford something like that (the program I have seen "at work" is actually not for sale but is available on a lease basis).
The fact that we wind our transformers on an iterate basis has more to do with not having this software; the equations I use are perfectly accurate and actually the same as in these software programs. Doing the calculations by hand just takes more time; the outcome however is equally accurate.
Allowable currents to flow in the copper wire per area (cm²) symbol S
S = 3A to 5A per cm²
for 100VA transformer I use 0.25 to 0.3mm diameter cooper wire for primary (220volt)
3A/sqmm, not 3A/sqcm.
0.3mm diameter and 5A/sqmm gives 353mAac
times 230Vac gives 81VA before accounting for efficiency. I'd guess at ~70 to 75VA for 0.3mm diameter and 5A/sqmm.
0.25mm diameter and 3A/sqmm gives 147mAac
times 230Vac gives 32.4VA. Reduce to ~25VA for output rating.
If my sums are correct then your primary wire looks too thin.
Can someone confirm where I have gone wrong?
Essentially right.
3A / mm² is for quality transformers, especially when temperature is a factor.
5A / mm² is for economy, where temperature, strayfields are not important.
Primary current is determined by secondary power (load), not by what the core might be able to deliver.
For example when I calculate a transformer which must supply 300 watts of secondary power, and I want B not exceeding 1T, I know a need a "600" watts core because of the larger required winding space. Wire diameter of the primary however can be calculated for 300 watts (no problem with the momentary higher inrush current at start up).
if i live in your part of the world, then our "real" worlds would have been similar.......
unfortunately, materials available to you is not available to me vis-a-vis cores, you know your core manufacturers, i do not.... you deal with fresh virgin materials, i use scrapped traffos and cores....
i build traffos that work, are not too hot to touch and doesn't burn out in use, i must be doing things right.....
I understand Tony, of course.
But be it your or my world, the same formulas apply.
Important to know is what core material we deal with; the difference between 0.35 and 0.5 mm is physically obvious. When the laminations show an oxyde coating you can be pretty sure that the material is heat annealed.
So we have already 4 possibilities, covering almost all options.
For these options the important data are easily to find on the www, also for you.
I would not rely on RDH3, 4 or whatever; mostly out of date.
Good luck with your projects.
Joined 2009
I know I am late for this discussion, but here are the formulas I used back in high school, when quality ready-made toroids were not available. I did design a number of hand made transformers with these formulas, and all worked reliably. These formulas are (1) oversimplified, (2) very conservative, made for poor quality iron, and (3) designed for 50Hz.
Power(W) = (Core-Area)^2; Core-Area is in cm^2
Turns-per-volt = (50..70) / (Core-Area); Core-Area is in cm^2
Primary turns = Primary voltage * Turns-per-volt
Secondary turns = Secondary voltage * Turns-per-volt * 1.2
Wire diameter = 0.7 * sqrt(Current), Current is in Amps
Looks like these are is agreement with the (complicated) formulas above.
Yes its should be mm² :sorry:
but I gonna confused with this image from my real world
no 1 = must be fake, 5A * 64v = 320VA to small for that power
dimension 3" * 2.5" * 1.75" (stack)
primary wire = 0.25mm diameter
secondary wire = 0.7mm diameter
no 2 = maybe its okay, 5A * 64v = 320VA, or maybe 5 * 32 = 160VA?
dimension 3.75" * 3.25" * 2.15"
primary wire = 0.5mm diameter
secondary wire = 1.2mm diameter
no 3 = was used in 30watt amp so its maybe quite good transformer, even the iron core is black in color, anyone know what is this core name?
all trafo for 220 volt ac input
the AWG table make me more confuse, from the shop that I bought wire they ask me in mm diameter not AWG's.
Can anyone show me the right AWG to metric conversion.
then for 0.25mm 0.5mm or 0.7mm diameter how much currents can flow safely?
Please tell me the actual reliable VA for no 1 & 2 ?
so my mind can be clear
I'm also read this
http://www.diyaudio.com/forums/power-supplies/191730-my-latest-traffo-build.html
very good traffo making, but tube is out of my range
Sir Tony, that winding machine is a DIY tool?
so cool :cool:
What about this toroid?
I hope this one is more interesting to discuss :)
but I still waiting someone to tell me the approximate VA for no 1 & 2?
Anyone can give me new formula for this trafo, please?
few years ago I made it,
it's okay or bad trafo
even the formula to make this trafo, I don't know
Maybe better if any suggestion to testing to know it is good or not
I don't have an AC A-meter
The gross over simplification of A= sqrt(w)/k is simply that: a rough fit for small transformers. Although, interestingly enough, watts = core area in (cm^2)^2 works out for a 50 kva pad mount transformer, a bit on the conservative side though, predicting 40kva.
IMHO, temperature rise is one single biggest factor
It is, and the reason is that volume follows the cube, surface area the square. You have to reduce the power loss, or reduce the current density. At some point, you simply can't make a transformer any bigger, iron loss alone would melt the core. I believe they top out at about 1 KVA per kilogram for near gigawatt capacity.. A 50 kva pad mount transformer is typically 360 VA per kilogram, and 98.5+% efficient. A 1 kva transformer might be 200 va/kilogram, and only 95% efficient, even if you used the same iron.
