Vertex Amp By apexaudio
blue ice,
amp is already working,limiter also working
picture on page 1 post#1 is working unit
page 1 post #7 the green 1 is updated pcb
if anyone want to help upgrade pcb is much welcome since driver transistor need to be mounted on main heatsink,we are in need of pcb expert like sir COOLET.
but amp is working and stable with measurement already post and with speaker load test by sir jay
Thanks Engel!
I'm currently looking for a place where to get the IR2117. It has been my ongoing problem since the H900 was posted. Hope you can direct me where I can purchase this one. Thanks again!
Blueice23
limiter with balance input
untested new board of limiter balance input and opa limiter is tested on separate board
lm13600
Yes NMOS 13700 can be use
Here is my limiter the 2nd and 3rd picture not yet tested with balance input /opa limiter and sub filter 30=50 hz
@andrewlebon 1st ic is for balance input you may or may not use it if you don't have balance input pls see reference in PDF
about 4050 im getting very slow on that project will keep you inform
Vertex With MJL
Vertex now Powered on MJL21193/94 IRF3710x6 Mur20200ct
its has big deference ,,it has more power details audio and first power tump is gone..
Measurement will be display later
