100W Ultimate Fidelity Amplifier
bc 550
I committed mistakes on bc550 pin configuration.its not in my eagles library and that time i have no internet in my room.sorry...:bigeyes:possible to check again if it will be usefull to you.
  • copper side.pdf
    copper side.pdf
  • schematic.pdf
    schematic.pdf
  • top view.pdf
    top view.pdf
Minimum +/-35V DC rail voltage, +/-50V DC maximum for AX17.
Single pair for +/-45V DC & 4ohm load maybe it's hot
If add 1 more pair what happen?
Need to add 2 more 0r33/5w, 2 more 1n4007, & 2 more 4r7
or I do need to change anything?
Here my PCB design...
It is okay? Maybe some comment please🙂
Pcb size is 10cm x 6,8cm
John
hi sir Apex...nice schematic you have AX17, AX18 & AX20...too many transistors used in the driver and pre-driver stage...sir apex... it is possible to add more power transistor to have an additional output from 200 Watts to make it 500 Watts...?
tnx...benny
Ok Dear Mr. Apex...
fair enough, I am just wondering why you designed some AXs..I am sure you have your own reason...I believe that AXs family sounds great..
I am still waiting customized toroidal transformer to feed AX-16...I up graded some electrolytic caps with available nichicon and sanyo from the local supplier....even not the best and audio grade components but the sound is better now
Now my AX-16 has better sounds in bass, clear high and crispy high..
Ok Dear Mr. Apex...
Can you post pictures of your work, and share expiriece, measurements...
Hi, Apex sir.
Can B80 amplifier work with more than +/-45V, and what need's to be changed?
Have a lot BDV64C/65C transistors, they are 120V 12A 125W.
Regards.
Also I have problem with some your amplifier boards that I trade with my friend. There is ~12V DC on output.
Will post pistures.
Hi, Apex sir.
Regards.
Will post pistures.
Amp on this pictures is D14 with 2 pairs of darlingtons in output stage, and you can use it with +/-60V DC rail voltage without changes but you must add another pair of BDV64C/65C outputs.
And again you must connect input GND with PSU GND for any test and measurements.
