I find most modern pop music has a negative effect. Sadly, even orchestral music from the Proms can be negative when subjected to modern ideas about processing. BBC sound engineers obviously don't listen to the stuff they now produce.
I never knew he had a cat.. I figured what with the piano and Lucy, he never had time for one...Does Snoopy like cats?? Or, is he too busy chasing the Red Baron?Never adopt cats which were previously owned by a German physicist. They remain indeterminate, while a proper classical cat can commute all day while sleeping coiled up on a mat.
Ohhhhh....Toes...Is it related somehow to Popsicle Toes Diana Krall sings about? 😕
I though she was saying NOSE... that explains a lot..
Ah, like that spinning thingy my grandaughter drops the paint on...There will only be a splatter pattern as a cruel demonstration of the wave-particle duality.
I have a stopwatch. So, if I listen while I'm timing, is somebody gonna brane me??If you want perfect timing in your music, then you can't know which note is being played so you can't tell which tune is being played!
You've lost me here...I thought they were mutually exclusive..Sorry, physicist's idea of a joke.
I kicked that Fourier guy off the jobsite. Now the masons can do what they wanted.....Fourier limits what you can do with brick-wall filters.
Albert and Amar ran a digital moonshine still??or maybe there's an analog to a Bose-Einstein condensate...
Wow. You guys on the other side of the pond got class...over here, they play hip hop and techno at the proms.
Cheers, jn
I can confirm Descartes is dead. Definitively.As an aside (and mainly to confirm I'm not completely losing it / imagining things), was there a link to a (IIRC) French forum lurking here a couple of days ago which seemed to be discussing a wire with a battery attached?
I want to apologize on behalf of my fellow citizens.
PS: I was the author for this link, i had edited, so , don't worry you where not under some kind of indeterminate state.
Thank goodness for that. I was getting worried. Talisker doesn't normally do that to me, but thought I best check. 😉
Keep alive, he does-it to me more and more with age.Talisker doesn't normally do that to me, but thought I best check. 😉
As an example, i'm am indeterminate to choose any of those 3000$ high-end cables. Main reason why i use an ordinary one, to be true.
(The second one is, may-be, the 3000 $ ?)
Blue cables add cold to sound.
Everyone knows one cannot "add cold," but only remove heat.
Some people seem to think that you can insert a box in an audio chain and 'add quality' to the signal. The box somehow knows what was previously there, but removed by other units, and puts it back again. To do this of course you need to find someone who is skilled in breeding Maxwell demons.Andersonix said:Everyone knows one cannot "add cold," but only remove heat.
I have been quite successful in this regard. They average 5-6 demons per litter, and we now have several thousand of them. Feeding is a bit of a problem for many growers, but since we have quite a bit of information at our ranch, they have thrived nicely. The colors don't seem to follow Mendelian genetics, unfortunately- I have been trying to breed red females, but apparently that color is sex-linked.
Probably. 😛
I've posted about such things before.
You see, by only feeding AC currents through your speaker cables, electrons can "settle", and become less and less reactive to the signals. The effect is a dull top-end, and smeared transients.
Attach a battery, and those electrons are constantly replaced by fresh, new electrons. The result is the top-end sparkle is back, and drums "snap" along like your system did when new.
Chris 🙄
I have heard that they have to be fed classical information, as quantum info just confuses them and they can't decide whether they are coming or going so they try to do both together and collide with themselves. Is this your experience?SY said:Feeding is a bit of a problem for many growers, but since we have quite a bit of information at our ranch, they have thrived nicely.
The problem with quantum information is that it causes them to anticommute, at which point we've lost them. Classical information puts them to sleep. So, we stick with bluegrass and country.
Most country artists wouldn't know a horse from a hose. Which is fortunate since demons are allergic to water.
I love that one. Makes-me remember to the Russia battle !electrons can "settle", and become less and less reactive to the signals. The effect is a dull top-end, and smeared transients.
Nb: you can recognize fresh electrons at their smiles, fresh shaving and clean shirts.
And, indeed, they are a lot faster than tired electrons.
Folks,
If this was Monty Python, you all would qualify for large grants from the Ministry of Silly Talks, to further develop your skills in this department. Well, at least until the Spanish inquisition would get hold of you and torture you with comfy chairs and only tea with scones at three!
Five years in Barber school!
Monty Python - Barbershop sketch/Lumberjack Song - YouTube
I never wanted to be in this thread anyway...
I wanted to be... a lumberjack!
Leaping from tree to tree, as they float down the mighty rivers of British Columbia.
The Giant Redwood.
The Larch.
The Fir!
The mighty Scots Pine!
The lofty flowering Cherry!
The plucky little Apsen!
The limping Roo tree of Nigeria.
The towering Wattle of Aldershot!
The Maidenhead Weeping Water Plant!
The naughty Leicestershire Flashing Oak!
The flatulent Elm of West Ruislip!
The Quercus Maximus Bamber Gascoigni!
The Epigillus!
The Barter Hughius Greenus!
The Giant Redwood.
The Larch.
The Fir!
The Epigillus!
Some of mine got wet last week-end and turned into chupacabras, you don't want to know what happened next.. 😱 😀
And on that note going forward perhaps if at all possible we should try to discuss things that vaguely resemble the original thread topic.. Or we could retitle the thread "What happens to your Demons when they get wet?" 😀
- General Interest
- Everything Else
- speaker cable myths and facts
