Simple Symetrical Amplifier
If I want to use 4 of 5 pairs of output laterals, what should be changed?
One pair of output devices is quite sufficient for the output power of this amp (40 watt). I have not seen anyone complaining of having trouble that built the Goldmund clone and discarding source resistors. I have paralleled 2SK1058/2SJ162 in the past not using source resistors and load sharing presented no problem.
Finally I am back at home and I see that very nice activity is going on here, especially someone had a lot of work, Alex you outperformed yourself, I am amazed, PCB 1.3 version is a pearl beauty. :cheers:
I Like this amp a lot. I like laterals anyway and i sometimes need a little compact amp. When it is ready i will build it. Keep the Laterals at the output. That is the charm. Even the first version. Great work on the PCB by the way. It looks really tidy.
Me too, in all kinds of versions future will bring. What is important that I presented to DIY is splitted current feedback loop enabling proper DC working point conditions of the input BJT pair and symmetrical input diff-amp modulation with the output FB signal. In this way the input diff-amp is modulated with evenly splitted (symmetrical) distribution of the feedback signal, thus leaves no chance to the input transistors to oscillate by any kind of parasitic resonant frequency.
Implementation of this basic FB core to any kind of amp is limited just by someone's imagination. 😉
I realy want too build this amp.
i have got plenty of 2sc2240/2sa970.
The 2sk1058/2sj162 is quite pricy at my lokal suplyer,35-40 dollares each:crazy:
Is matching neaded of output pairs?
What VA rating will be a suitrable tranformer for monos?
I will try too etch my own pcb.(as soon as layout is ready)
Thanks Lazy cat,Nico and Alex for your nice work.
I redrew Juma's circuit schematic, one more time. The redrawn schematic (finally) made the circuit's operation obvious, to me at least.
  • It's a two stage amplifier, both stages provide voltage gain
  • First stage is a cascoded BJT common-emitter amplifier
  • Second stage is a common-source MOSFET amplifier
  • (R3, ZD1, C2) and (R4, ZD2, C3) create DC bias voltages of +15 and -15 for the cascodes
  • Negative feedback is applied to the emitter of the first stage
One surprise that emerges from this drawing but not its predecessors, is: capacitor C4 is connected across two nodes that are perfectly in phase. So the AC current flowing in C4 is: zero. I didn't realize that until seeing this drawing.
AAAAA-AND, the drawing prompts the question: What if the MOSFET output transistors Q1 and Q2 have different "threshold voltages" (VGSon) or different transconductances gm ? There doesn't appear to be a way to trim the positive (P-MOS) side, independently of the negative (N-MOS) side. Please, if I am mistaken, point out the error. Viciously and without remorse.
Welcome to the thread, you're invited to built SSA (PCB V1.3) to share your listening experience with us. 🙂
Yes there is 1,2V DC potential across R16/C4 defining bias conditions, but when FB signal modulation starts, this potential tends to change because R11 & R12 are not current generators and there is also a hFE difference in input pair, so to keep this potential unmodulated DC the C4 is needed as a simple solution. 😉
Please see the post #36 where R12 from you sch is changed with 2k trimmer to balance the circuit to zero DC offset at the output. 😉
