Potential EUVL F5X designed case user distribution check
Nic,
I'm being soft today...
Since you have also been doing a great job with the PRP GB, I'll make one exception.
If anyone opts out, you'll get that. If not, we'll make one extra for you.
John, once you have collected payment for case and sink from all 25, drop me a email.
We'll then confirm that Nic can have a 26th !! And my apololgies for extra work for you.
Patrick
> I have to pay for regulator heatsinks for two chassis.
> Is that 20euros extra or 40euros extra?
2 regulator heatsink per case is 20 Euros.
So for 2 cases it is 40 Euros.
But since you are only payment 50% down payment now, you pay 20 Euros.
The remaining 20 Euros you will pay when the cases are ready to bulk ship.
Clear ?
Patrick
Thanks guys lots of payments have come in;
Horio - Conrad Sinks + Case(s) and Regulator heat sinks received PAID "ouch"
scranton - Case and Regulator heat sinks PAID
JBdV- Case and Regulator heat sinks PAID
ramallo - Case and Regulator heat sinks PAID
Andrew T - Case and Regulator heat sinks PAID
Spread sheets updated:
Heatsink GB Payment list
https://spreadsheets1.google.com/sp...npK-FZmcf9ttQ&hl=en_US&authkey=CKuU0-8O#gid=0
F5X Case and Regular Heat Sink 50% payment list
https://spreadsheets0.google.com/sp...oI7Zpdvx7pzEw&hl=en_US&authkey=CIT5trAJ#gid=0
Cheers
John
Tomorrow I will try to order a sample of the proposed IEC to check the quality and ...
Today I got the IEC module from Farnell. Attached two pictures. For me the build quality is OK. Furthermore I'm sure the remaining 10mm between the transformer and IEC are enough for the wiring. I've also checked the dimensions, of course they are the same as in the data sheet.
Patrick, one additional question: the IEC module is for snap-in mounting, according the data sheet the panel thickness shall be 1.0/1.5/2.0/2.5mm. Is the thickness of the rear panel in this range?
Uwe
