Thanks a lot to Epa and the other experts for helping with this project.
Epa
Djim
Tb46
Jbell
Jricci
Bjorno
Thanks alot
Epa
Djim
Tb46
Jbell
Jricci
Bjorno
Thanks alot
we want pics of the bilding proces.😀
Will do
Once i have all the parts building will start
I personally use flattened expanded mesh. Here's a pic of some cb-18 using the same mesh for grill for inspiration. (it really stiffens up the front panels, and keeps things from vibrating)
Nice grill
jbell, Thanks for the info
Does that explain you absence? 😉
nope... just been busy. that pic was a gratuitous copy from a speakerplans post -- not mine.
Since that builder used the same grill material as I do, I thought it might be helpful to cross post the picture.
(btw -- right now my shop is littered with test cabinet designs -- when I have something of value to post -- be sure, I will....)
Cool project, look forward to seeing a build of this! Didn't know you could horn load a cone as big as 21", or is it fine becuase it's a tapped horn?
Thanks Dr, it was design was by Epa.
[special=]%[/special]
the plan has changed a bit.
you can load any speaker to a horn.
its just that some wil work better then others.
you can make panels 10 and 11 12 mm wood,no need to make them 18 mm heavy.
Good morning Erik, I see you still tweaking this cabinet. I like a person who take pride in there work .
Thanks.
hi stanleyGood morning Erik, I see you still tweaking this cabinet. I like a person who take pride in there work .
Thanks.
wel i was looking over the design,when saw this.
it maybe saves 1 or 2 kg doesnt make much difference tho.🙂
- Subwoofers
- R evenge C omes with F orce
