AD1865 the best DAC
I recently purchased a DAC TDA1541A+WM8805 NOS 1.0UI multi-input from raindrop_hui on ebay. I cannot get any signal out from the analog out on the board. I have tried troubleshooting, but I am a novice when it comes to digital electronics. The communications is strained because of a language barrier and the most I've gotten from Mr. Zou is one email a day. I found some troubleshooting tips while scanning the site for Lesha's DAC. There is a voltage table of the TDA1541A pins posted on the site. According to it the voltage on pin 26 of the the DAC should read about - 5.1 volts. It reads -2.211 volts. I informed Mr. Zou of this and have not heard from him since.
Can you trace a digital signal with an oscope?
With regards to Raindrop_hui 1865
I notice that the power transformer 18vac is converted to 15vdc and then to +5vdc/-5vdc while the transformer 9vac is comverted to 9.75vdc and then to 5vdc.
So is it ok to substitute the 9vac transformer with a 12vac transformer? And what is the purpose of the dual regulation when the 15vdc and 9.75vdc are not used at all?
Today I conneced my AD1865 DAC with LL1578XL on the output:
The gain is a little on the lowside,I have now a 200ohm resistor on the output
Will I get higher gain if I use a say,400 ohm resistor?
The sound is a little dark (don´t know how it is with the tube output?)
Yes, you will get 6dB higher output amplitude with 400 ohm I/V resistors. My experience is that the AD1865 will still produce excellent sound with a 400 ohm passive resistor I/V. This is a relatively rare ability, one shared by the PCM56. If, however, you are directly driving a transformer from the AD1865 outputs, the higher I/V resistor value effectively raises the source impedance as seen by the primary, not something to be desired in itself.
If this is a un-equalized NOS (digital filterless) design, then it might indeed sound a little dark, due to the well known -3.16dB @ 20kHz zero'th order hold response roll-off.
I/V resistor not shown, sound is much better than SRPP (I compared).
And what for is that 0,015uF cap between grid and cathode?
Using the Trim/Offset on the AD1865N
Hi...
I see there's been no post here for a long time....hope I'm not alone out here!! 😱
Question: Has anyone used the L/R TRIM pins on the AD1865N (will be using the K version) and noted a perceived and/or improved sound quality? To test this I imagine it will take a test CD with tones low enough to establish distortion at 60dB down?
Thanks,
Gary
