Bora is a nice guy from Serbia - Yugoslávia
You have to contact Dr. Bora for the material.
My Sigma Build
Hi all,
Thanks to Dr Bora's advices, I have completed my Sigma Lateral-MOSFET amplifier and had been listening to it for a couple of weeks. I am impressed with the sound quality and it is one of best amplifiers that I have listened to on my home setup.
The bass is tight and controlled; the vocal is sweet & clear and the high is detailed. Overall the amp is musical and it does not exhibit any harshness at any frequency. I love the sound of this amplifier.
I used the Sigma schematics as published on :::Borina Amaterska Svastara:::
I used the recommended semi devices as detailed in the schema & I made my own PCB.
My supply voltage is 63V
I biased the output MOSFET to 100mA
The amp is dead quiet with no hiss or AC hum.
There is no turn-on or turn-off thumps.
I used an old E-I core transformer & the acoustic noise from this transformer is the most annoying source of noise of this build.
Cheers, Stanley
You can have PCB and layout files for 3Way X-over if you mail me on my direct E-mail.
I am not sure that I understand what you are going to do because that is not a tone control and there is no point of joining together outputs from this module!? This unit should go after some kind of preamp (with or without tone control) and outputs should go to 3 separate power amps to drive three separate drivers in 3 Way Box to avoid passive crossover.
Just for you nazirdigi...Work carefully and you will not have problems.
thank u victor for this pcb.
is this new version or old version?
did u made this amp?
how many watts for this amp?
what is maximum voltage of dc?
there are two pots in this pcb and i think one is for bias and other one is for dc offset am i correct.
how to adjust these pots pls explain.
1. This is the latest version
2. No, but others did
3. 100W 8ohm
4. Should be used +/-50V DC power supply
First of all make pcb, solder all the elements and then we'll adjust easily to.🙂
