DIAMOND DIFFERENTIAL INPUT POWER AMPLIFIER EBay kit
This is very true, Forr,
This particular amp has two patents (self regulating VAS current and something else if I remember correctly) but the drawback was that this amp (and possibly other Sansui amps as well) operated on the verge of stability. I never had any Sansui equipment and I am not really familiar with their designs. Simply when I saw this kit on EBay I decided to check the net for similar designs before deciding whether to buy it or not and found this Sansui.
cheers,
Attention,
the most recent simulation with Beta24 of the DDInput amp showed that R16=220 with W2 and R28 out of the circuit. Or R16 in parallel with W2 and R28 should be set to 220.
Has anyone already finished building this amp?
cheers,
At last.🙂...the amp is finished....sounds great...had some problems with fake devices..sorry for the delay.
Fakes were output devices (ON-Semi NJW3281...)...the emitter resistors bad quality too...once replaced the unit works fine..two buyers are available: Tubeshunter and Jimsaudio..Tubeshunter don´t send any information..and the boards are different too from different suppliers...Good luck.
How did you find out they were fakes? Did you check Hfe at high currents? I have tested hfe at currents from 10uA to 20mA and these which I got were pretty linear. Did not test them at higher currents.
Where did you get quality non-inductive resistors?
cheers,
Well,first of all most of devices from ebay are fake...this is well known..mine exploded litterally with only 50V. per rail..sent photos to On-semi and they confirm this ones were fakes.
My resistors are buyed from an ebay supplyer.
