Mic, Line, EQ... Preamps
Correct.
This scheme needs positive and negative power rails.
Look at the top left corner of the PCB design, there are the 3 power connections (GND, +Vcc & -Vcc)
i saw in the website only two connection given. why is that. i'll post the image.
in the parts list there mensioned 9v dc 300ma trafo.
if i put 12v ac dual supply 1A trafo is it ok?
PCB size: 60x50mm
thank you Mile I build this one and its very good for sub I test it with dual TDA stereo as I build before the result was great and sub is shaking the room, here the PCB with PSU I used for it.
top:
attachment.php
button:
attachment.php
power supply from 35v:
attachment.php
but I still have question about two things what is AUTO used for?
and speaker input I didn't use it just use the line in again when I can use them?
AUTO post signal to auto-start circuit, turn amp on if signal present and turn off if there is no signal after 5 minutes.
If there is no line-out connect on your audio system, you can use signal from speakers outputs and connect to speaker input on this x-over.
ASK TONE CONTROLL MR APEX
I've assemble tone with potensio 2x50K controll apex.
I heard the high voice is not good but if in a low voice I feel pretty catchy.
I question whether the components that I use have to be replaced?
help me Mr. APEX.
greeting
The following picture
