8,8 meter basshorn "6090 Monster"
I think that is what you might call overshot the mark
all you need is to take 1-2 feet from your room
build a cheat wall
it should be plenty space for two bass horns
maybe also consider the woofer
drivers originally used for horns were different
modern woofers could make it 'easier'
it doesnt really need to be that big
its what I would call the deception of mysteria and myth
just an idea, a thought
its even easy to mount a 'door' on mouth opening
and opened, this 'door' will support even further
yes a tapped horn(tqwtp)
its the top one of the pic.it uses 0,35 m2 floor space
the bottem one is a th ,its a bit bigger and louder.
its moddeled with the bms 18n 860(x-max 19mm).
havent actualy bild them🙂
if you planning to bild them i could provide details
