500W PA amplifier with Limiter
Hy! I post some pics, comment it if you want.
Apex: I modified the protect board, i hope you don't mind. I used my favorite relay, and so the board needed to be modified.
I also made a psu, 80.000uf/100V total, i hope this is enough for 2 of this B500 amplifiers.
which power supply do u use?can u share the layout and top.
apex,
can you share input volume schema using balance input(using g,a,b)🙂
Hi.
with the knob towards the operator and the 3 connections pointing down, you have a pot that gets quieter as you turn the knob clockwise.
Most listeners prefer clockwise for louder. This requires you to swap common (Sig Gnd with Input)
You can "see" this mechanically.
Turn the knob fully anticlockwise. The wiper will now be positioned at the stop next to Input. Wiper taps off maximum signal level (=loud).
Turn the pot fully clockwise till the wiper hits the Common stop. The wiper now taps off a near ground signal level (=quiet)
Hi.
is this correct?
