Placid-BP Bipolar Shunt Regulated Power Supply
I noticed that some are using other regulators than the Placid for the Buffalo DAC. Is better performance attainable with other regulators? Will the Placid be improved upon or do you feel it's as good as it can be? What about using a higher quality bridge rectifier etc?
When using the Trident local shunt regulators, the BII's current draw is a little beyond the optimum current range of the Placid. It still works fine, it's just more current than it was designed for for lowest noise. Because of this, many use the LCDPS. When the Tridents are installed, the performance is really dictated by them.
Replacing the rectifier on the placid will yield a vanishingly small change, if any at all.
Thanks for your quick reply. I am considering building a Buffalo DAC and would want to make any worthwhile improvements I could the first time. It's hard to tell, just by reading forums, which changes will yield the largest improvement.
Brian,
Any recommendations on changes to the Placid to be better suited to the ~500mA current draw of the Buffalo + Trident set up?
Cheers
Martin
