100W Ultimate Fidelity Amplifier
Here i'm again...
The two channels are working fine. Bias at 1,3V (best for my taste). Box is not finished but in good way.
Regulated psu 40V 4X10000uF for each channel.
2X120VA Transfo.
Good Bass.
Offsets: 3mv and 5mv. Need absolutly the wiring from Apex.
Transfo 2X30 AC (2X33V with 240V) , 45 DC regulated to 40V .
Too much projects for metal case, but i'll use a métal cover.
Heatsinks are warm but it's ok.
AX14 is giving very low bass. (my woofers can give 30HZ and i "feel" the bass in my body.
You have only 120VA transformers but PSU with 4X10000uF regulated on +/-40V there is no any rail voltage drop, and You have very low (good) bass.
I must suggest to use NX14V2 pcb. This pcb is fixed on heatsink, and you soldering outputs on coper side of pcb. Montage outputs is much easy this way, and connection pcb on heatsink is much stronger, not just transistors pins.
HI Apex.
All the search for input selectors with volume control and remote controlled, has been very messy, Requiring atmel programming skills. Some thing new for me which i have not ever done.
Sir, can you suggest any thing which would help me with at least 4 pair of inputs and 1 direct input which could be switched with potentiometers. I cant use dact switchers, too costly.
or if any thing which can help me with remote controlled input selector and volume control.
Hi, apex i am from india and want to build ax14 because i am beginner in audio amp
building and this is a good (not complex) design for beginners. kindly give me some
links of your amp designs.
i have posted my query about pioneer sx 3800 (Thread- Help! pioneer sx3800),but
nobody is replying my post. kindly open this thread and reply ,if possible.
thanks in advance. sorry for bad english.
