what etching solution do you use?...
Ferric cloride (anhydrous brown one)) +water it give decent etching but some pit marks.I am using tonner transfer method for pcb layout
hi apexaudio
greetings waiting for your help finished vertex 3 step driver want
to attach with h900 can you share modifications please
1 my ac ttransformer is 3* 24 0 24
2 output transistors 2sc5200 2sa1943
thanking you
andrew lebon
thanking you
andrew lebon
hi apex,
i have completed my board lot of mistakes in marking of components in the pcb.finally
its working with bulb and 10r series resistor in both the rails.732mv across possitive 10r and 632mv on neg 10r i can hear the clear buzz in the speaker.when i touch the input.30mv on speaker terminal using only a pair of output.ill complete it step by step.
r24/25 heating a lot (1k) will be changing it to 3k3.
right now iam using 60-0-60vdc.what should be the value of r22/23 for biasing for 2 pairs of outputs only for testing purpose.
thanks in advance
ravs
be a vegeterian......
thanks in advance
ravs
and you use the electric iron to transfer the toner, i am right? and you add a little of water to the ferric chloride...what program do you use in pcb making?..can you give one...
hi gooseneck
greetings use SPRINT LAYOUT 5.0
download from KICKASS TORRENT with crack
thanking you
andrew lebon
thanking you
andrew lebon
hi apex,
do oscilations makes bulb glow brighter.i increased the length of leads of mje15032/33 and mje340 sleeved.the bulb started to glow continuosly.different voltages on collectors as we move away from the fuse.checked for shorts . removing the transistors and bolting them to sink and connect through wires make things normal.or is there any other problem.is my amp oscilating.ill post pictures tonight.
thanks in advance
ravs
be a vegeterian....
thanks in advance
ravs
be a vegeterian....
hi apex,
thanks in advance
ravs
be a vegeterian....
Is your zobel resistor 4R7/2W hot?
I would expect so.do oscillations makes bulb glow brighter..
If the amp has been set up with near zero output stage bias then the Power consumption is very low.
If oscillation sets in, then Power consumption will increase significantly.
If you test start up with a low wattage light bulb then it should be sensitive to any fault that increases Power consumption.
As you turn up the output stage bias, you will find that the light bulb starts to glow. Stop, back off the bias slightly. Change the bulb to a slightly higher wattage. Increase output bias until the bulb is just not glowing.
In this state the bulb will see any further increase in Power consumption as a smaller proportion of the total consumption. Mild oscillation might not show as extra glow. Bad oscillation should show up easily.
sir apex can i use 5amp relay for speaker protection for one chanel. i cant find 16amp relay.
Yes but only for the test.
hello mr apex
hello mr apex. i want to build your amplifier i order all parts and next week i will start the job.i want to ask what else should i build for complete amplifier? the module amplif, the protection circuit...and what is the vas stage you present in this forum? can you show me how to wire the vas stage if is necessary?
thanks in advance!
thanks in advance!
apex,
using MJL21193/94 7pair
using MJL4281A/4302A 7 pair
tripple ef
2 kva 40,000uf caps per rail
what are the difference in psu with this two MJL and power in WATTS if build?
tripple ef
hi andrewlebon sekhar,aman,sudhir
what are you paying for c5200/1943 pair
iam getting 75 rs for a pair original toshiba
reards
ravs
80Rs/pair ,here in bangalore.
hi sudhir,
iam getting toshiba original for 65rs.if you buy 100 or more it will drop down to
62rs a pair.mje15032/33 touching the sky 110rs a pair.
regards
ravs
hi apex,
sorry it took a lot time to take photo and make some video.
no my zobel is not getting hot at all.
here are some pics and videos
some videos as well
1 heatsink bu.flv
http://www.youtube.com/watch?v=XxGGkKdmIwY
2 bulb without heatsink.flv
YouTube - 2 bulb without heatsink
3 only outputs on other heatsinkk.flv
YouTube - 3 only outputs on other heatsinkk
4 drivers also on other heatsink.flv
YouTube - 4 drivers also on other heatsink
5 difft readings on collectors
5 Difft Readings on Collectors - Video
6 current without speaker.flv
YouTube - 6 current without speaker
7 song playing
7 Song Playing - Video
audio2
Audio2.flv - Video
do you think its gonna work.or is it any other problem
by the way i made the pcb mirrored so all the components those were
on left are on right side and vice versa.this is third time iam doing same mistake
thanks
ravs
1 heatsink bu.flv
7 song playing
audio2
Audio2.flv - Video
thanks
ravs
I would expect so.
thanks andrewt
regards
ravs
hi apex,
Do you connect input GND to PSU GND? If not there will be high DC offset on amp out.
hi apex
that didnt made any difference offset becomes 20-29mv.
without any series resistor but bulb why my positive voltage 61volts
and negative 14 volts on the fuse.and different values on different collectors.
it happens when i connect c5200/1943.with drivers it is normal.
do you have any idea whats going on.
regards
ravs
be a vegeterian.......
- 900W H-class PA Amp with Limiter
