The beaty of p2p wiring
Didn't really end up; I never finished that amp. It was more of an exercise in introduction to p2p wiring. I later built Aleph 5 this way though: http://www.diyaudio.com/forums/pass-labs/4018-more-beauty-p2p-wiring.html
Recently, I've built few DACs using p2p method and I'm very satisfied with the results, in fact this is my best effort yet 😉
Peter, in post #4 in your "More beauty of point to point" you show a pic from the top that reveals 3 out puts on each side. What are those thick pads under the outputs? Or is it just the reflection off the heat sink surface that makes them look that fat?
Thanks in advance,
Russellc
Kind of an old hat, but anyway, here's my p2p Mini Aleph built inside a heatsink (15cm wide/high/deep). Toasty.
And mind you, I built this using lead-free solder (99% Zn and 1% Cu).
In the 5th picture you'll notice that the Zener is facing in the wrong direction. That cost me quite some nerves. And yes, the IRF9610's are mounted with superglue. 😀
As in post 64, I had the idea of using a plastic as a capacitor frame. I bought some nylon block and found it surprisingly unhappy about my drilling (smoke, etc). My question is whether I should persist with Nylon, or try and find an easier to work plastic? The ebay shop where I got my nylon block also offers polyethylene, polypropylene, ptfe and others. Any suggestions would be most welcome
btw, how does it sound?
Very sweet. I'm feeding FE108EZ horns with it. The bass lacks some control that a LM3886 with regulated supply could offer, but the Mini-Aleph's midrange sweetness is unique. At least to my ears.
Be careful with ptfe, fumes and smoke from ptfe can be can be highly toxic and corrosive. I imagine machining polypropylene is not wildly different from nylon, but I'm no expert with these materials. You can find many article on machining polypropylene though, and it seems to be quite cheap.
Use some liquid coolant to keep the plastic's temperature down when machining. Alcohol (Isopropanol) or even water should do the trick. Stay away from acetone, it dissolves many plastics. Polyethylene is resistant to actone though, that's why the squeeze bottles are usually made of it.
