Simplistic NJFET RIAA
found this for free 😛, but need a beta tester......
Hi nicoch46... where did you find this literature ?
Why does the author state the need to turn the preamp on before doing the demag trick if it is done with the rca´s disconected from the preamp ?
Did you try this ?
I know it will not cause any damage but the text itself is quite suspicious :treasure:
What about the type of record... should we do it with loud metal or soft chamber music ?
Just for pleasure
Ricardo
Merlin, yes they are the same I am using, only 2m. Regarding sound, only by comparison you can tell. I compared it to some old Audioquest Emerald, Roksan and some DIY I have and they were better.
I'm using Kimber KS Select 1030 1.5 m silver & teflon also.
My cables don't have same connectors, have the WBT without solder but old model.
How much do they cost? I think for this kind of money there are other things to do to your system in order to get better sound. One of the best systems I have heard, used ordrianary cables!
They are supposed to be looking on separated load nodes. Or at least that is what I thought was the idea. I would prefer to give chance to a dedicated first stage low Z active noise filter on the rail than all this complexity and dissipation non the less.
