500W PA amplifier with Limiter
b500 power supply added another pair is this ok for 4pair of outputs.
can i use other power supply,protection,soft start for b500. is this power supply for stereo.
nothing is happening my dear i use 5200-1943 as drive because i have no 15032-33.
so u can use 5200-1943 its simple.
nd there is a mistake in pcb i show as a blue line ..make it and enjoy..😀😀
thank u
Hi aman khalsa and all.
Thank you aman khalsa for final check B500 easy drive and i corrected for PCB.
Regards.
hai apex.i build your b500 amp.using 2 pair power output.when i supply +-50vdc amp cannot work but when using example +45 and -50.it will work.so it work when negative power supply more than positive.and when at 9 o clock still ok.but when 10 to 11 it will unstable.what my problem apex?
i follow your pcb 100% same.
Post some picture showing wiring and close up picture so we can help you
since Apex is not online
