Who manufactures your new transformers?
The raw transformers are made in USA by Heyboer. I purchased mass quantities of end bells separately and had them powder coated with RAL9006 which is a metallic called White Aluminum. Looks very nice, similar to a pearlescent finish.
Also, dont know what your sourcing is for a majority of your parts and the chassis, but have you communicated with this guy?: http://www.diyaudio.com/forums/tubes-valves/179216-cnc-aluminium-chassis-tube-amps.html Some of his CNC work would look and be great if it was powder coated! And he is as enthusiastic as this thread is also to "mass produce". Now if I could just find a decent woodworker for the other portions of the chassis...
The chassis that will be part of the full kit will be raw aluminum with walnut side panels. You can see a photo at post #82. As far as the woodworking you might want to get in touch with "jmillerdoc" who is a member here. He does excellent work.
I am interested - if you are willing to skip the power trafo from the kit. Interested in the chasiss though, so not the basic kit you offered but almost the full kit minus the Trafo.
I would like to source one locally to reduce shipping weight.
The chassis I will be offering will be precut for the lay-down style transformers as pictured in post #97, so unless you can source this style in the exact size, your only option to be able to use this chassis would be to custom cut an aluminum plate that would cover the transformer cutout and mount with the existing transformer mounting holes. You could then mount a standard stand-up transformer to the plate. This was something I had looked into briefly but I have been so busy trying to get this initial build going, that option is kind of on the back-burner for now, so to speak.
Looking good! 😎
I like your avatar. It reminds me of something I did once as a toddler. It must have made an impression since I still remember it to this day! 😱
The ebay offering is for a partial, "Made In China", PCB. There is no valid comparison with the comprehensive kit Scott is offering, price or otherwise.
If you can give me the dimensions for the power Trafo mounting holes, That will help me check with my vendor. I have a local vendor who makes R-cores.
The power transformer is a standard EI 1-1/2" core, mounting hole centers are 3" X 3.75".
beta builder
Just wanted to let you know if you need a guinea pig to build a kit, I would be happy to help. Never built a kit before the most has been wiring and soldering a crossover network. Your work looks good so far.
Danger! Danger! Warning! Warning! Good job on the manual so far especially for extreme noobs. Lots of input and helpers in this thread so far to get your matched multi input preamp in the works too...
Happy Holidays you all.
Manual looks good, but we need to see actual assembly instructions. One good role model for manuals is Bruce Rosenblitz's Grounded Grid manual - if you have access to it.
I cant wait to order this kit, the itch has started ... 🙂
Cheers
Cheers
I'm prepared😀
Do you have the price for the complete kit now(with chassis,transformers,tubes aso)?!?
Just to save some money from the christmas shopping....
I'm prepared😀
When ready for sale the complete kit will be $849.00 USD + shipping.
Basic kit: $299
Tube Set: $90
Chassis: $120
Power & Output Transformers, Power Choke: $340
Hi Scott,
Your manual looks good to me. It look like it is also for beginners.
Just one question: Can you estimate the shipping to europe?
Happy holidays
Christoph
Happy holidays
Christoph
- Tubes / Valves
- KT88 SE Complete Kit
