I really wish we could revive this thread. This is a fabulous amp project and I missed out on the first group buy for boards. If anyone ever gets around to making some more PCB's for this amp I want in.
Cheff is in a class by himself with his imagination and skill set.
Please someone step up to the plate and get this going again.
Tad
Tad
Ok I have a couple of questions about this amp.
1. Can it be done with 2 pairs of output mosfets per side not like original 3.
2. can the output stage be on 30V like front
3. and what is the gain of amp.
4. That’s all (thanks)
5. I guess I sad thanks too soon
Same goes for me. While on the subject, does anyone have an extra set of those UGS preamplifier PCBs ?
NYCOne, you're a lucky man 😀
Itsmee bought my UGS power kit but he already has PCBs 😎
So make an arrangement together and let me know.
Please don't forget the shipping cost
I had the same problem - wanted to build an UGS Preamp when there wasn't any group-buy for the boards. Here is one solution - although not the cheapest one.
The UGS All Inklusive PreAmp and UP PCBs for our french colleagues were made by PRINTED s.r.o. in Europe.
I asked the company for a price to produce a single set of UGS boards.
They already had the mask-files, drill-files, etc......
Price was: 164€ (215 US$) plus tax and 35€ shipping.
Boards were nice quality (35um copper, galvanic gold plating, green solder masks, silkscreen printing, dividing by shearing/cutting).
It is of course not cheap to produce only 1 single set.....
But if you need only one UGS or UP PCB set and there isn't any group buy.....
UP Amp PCB
UGS Preamp PCB
I am new to amplifier building, but here is what I found on the french forum and in Nelson's docs in respect to your questions.
Should be ok.
The output stage has some similarity with the Burning Amplifier BA-2.
I recommend you to read the BA-2 manual on Pass Diy webpage.
Nelson Pass describes there the options to have 2,3,4 or 6 output devices
and needed bias adjustements.
This gives you +/- 24 Volt DC and about 42 Volt peak between the two speaker poles.
The 30Volts for the Frontend is generated by a voltage doubler circuit on the UP boards from the 24V DC. See Power-supply schematic of UP-amp.
RFB=392K/RIN=27K/ROUT=1K -> 22.1dB
RFB=392K/RIN=27K/ROUT=10K -> 23.1dB
RFB=392K/RIN=22K/ROUT=1K -> 23.7dB
RFB=392K/RIN=22K/ROUT=10K -> 24.8dB
RFB=499K/RIN=27K/ROUT=1K -> 23.9dB
RFB=499K/RIN=27K/ROUT=10K -> 25.1dB
RFB=499K/RIN=22K/ROUT=1K -> 25.5dB
RFB=499K/RIN=22K/ROUT=10K -> 26.9dB
Should be ok.
You will need only one torroid per channel: 2x 18Volt AC, 400VA.2. can the output stage be on 30V like front
Default setup is 23dB. You can change the gain by adjusting some resistors.3. and what is the gain of amp.
I am aware that 30V is generated by voltage doubler but I like simplicity and want to avoid it. So can it be done like front end or output stage? (I mean voltage 24 or 30V). And I made BA2.
Let's take a poll.
Who would buy a set of boards if they were produced again?
I'm in for one set.
I'm in for one set.
Just two questions resistor 442R I cant find nowhere, what value should I put 432 or 470?
And just to be assured when adjusting bias trim pot must be on maximum resistance?
I need only Trigger and Vu-metre boards of Up amp.
If possible fine, if not I am in for a complete UP board set.
442R metalfilm 1% Resistors are available e.g. from Farnell or Digikey.
Or you you could put a 432 in series with a 10 ohm resistor.
In the end 432 and 442 is only a difference of about ~2% - not too much difference anyway, but I guess you will have higher minimum bias setting.
About the bias trim pot:
Here are constructions notes for the UP Amp.
UP Amp construction notes (french)
Unfortunately it's in french, but google translate helps - sometimes.
"Les ajustables de 100Ω sont à régler de manière à obtenir la résistance
maximale lorsqu’ils sont soudés.
Ce réglage à la résistance maximale permettra de démarrer avec le courant
de repos le plus faible possible, ça évitera sûrement de la fumée 😉"
translates to
"The adjustable 100Ω should be paid to obtain the resistance maximum when they are welded.
This adjustment to the maximum resistance will start with the quiescent current as low as possible, it surely will avoid the smoke😉"
Hope it helps......I am an absolute beginner in electronics.
translates to
OK thank, I am also practically beginner
- UGS Power : it's U.P.
