Thanks Nar ,
You have a really good point ... in that , if I cant rely on the tolerance of the silicone to be as closely matched as the fets ,using matched fets is pointless ..
BTTDB = back to the drawing board ....
Ill just stick to the first idea of using wire .... or this ?
Thanks Nar ,
I think you got it wrong. I'm sorry and I apologize as English is not my native so I still do some horrible mistakes 🙂
I was just wandering, not guiding you to the drawing board 🙂 Come on 🙂
It's not the tolerance of the silicone that I was pointing out. Once you'll block it between the metal bar and the mosfets, then applying torque it will be tight. I was just wandering if the silicone would be as stiff/thick once it would have reached roughly thermal operating point. If it goes a little softer it might loose the stiffness it has at ambient, and thus loosing the applying strength of the mosfets onto the metal sink.
Once the "absolutely best" method for clamping has been described, I think one more hole wouldn't hurt to get your work done nicely 🙂
Not really off topic : I always tried to drill then taper the holes in the raw aluminium. However it's not the best idea as the metal itself is not very hard and after some unmount/mount of the devices, it can happen that the screw doesn't hold the fet anymore ... so thermal coupling can be ruined 🙁
I wonder if someone already used inserts ? metallic inserts so you drill the sink at a higher gauge, then hammer down in a metallic insert that is already tapered ... maybe even wood inserts could work ... Any opinions ? Just a hint though
Best,
nAr
No need to be sorry
Nar ,
I appreciate the input. This is my first project. The silicone layer may or may not work ! I have spent too much money and time on this project already . I will KISS as the say get it done and running and think about my next project !
I guess drilling more holes is possible . The better the contact the higher I can crank the bias . Ill have to wait till I get the ally bar . I will just use silpads between the back of the fet and the bar .
You talked about the tapping and drilling .... I would use a thermal epoxy if a repair was needed of that kind 🙂
BTW,I had a look at your cables .... beautiful work sir !
Rich
Nar ,
Rich
Nar ,
Rich
Thanks for your input, however subjective cable sound research is for now stopped - no money and extra time to finance that as I also have to make a living - that doesn't exclude the possibility to make high quality DIY interconnects for me 🙂
And yes, I have spent many hours ( for free ) on the website as I created almost all graphics 🙂
Best,
nAr
Nar ,
Rich
Rich, can you explain a bit more what you would do with the thermal epoxy?
Sure Steve,
If I stripped a thread ,whichI have done in the past .
1, drill out hole , at least .5 mm larger than the size you need .
2, Tap thread at the new hole size .
3, clean out hole with acetone = nail varnish remover ( dont get caught by the Mrs during PMS )
This step is very important . I use a syringe to force the acetone in to the hole . It will evaporate leaving surface degreased and ready to glue.
4, mix epoxy and some metal powder. I use brass powder that I got from an art shop .
I have been working with resins in various applications for many years and Devcon
is my prefered
ITW Devcon
5, lightly coat olive oil ,or any light oil on the threads and wipe thread with a cloth ,
just wipe ,dont rub .
6, fill hole with resin using a large syringe . You can get them from the drug store .
7, place your new screw or bolt in the hole , tread the screw in , if you just push it
in your will get voids.Let it set , a warm lace is best . Resins cure better with
a little heat .
8, remove screw and finish flush to existing material .
9, I always lubricate all threads when fixing the screw for the final time .
Rich
is my prefered
ITW Devcon
a little heat .
Rich
Wow. OK the critical thing seems to be no grease in the hole, enough on the bolt and the epoxy will stick to one and not the other.
What's the role of the thermal part of the thermal epoxy? Does that mean it is heat curable?
Sure Steve,
is my prefered
ITW Devcon
a little heat .
Rich
Thanks for the tip 😎 really awsome, technic but requires the adequate elements 😱
Best,
nAr
Have you tried Helicoil inserts. Possibly easier and more reliable solution for stripped threads.
Sizes M3 and up.
Cost effective solution for me despite sourcing to Australia from a UK supplier on eBay.
Nar, these screw in rather than hammer in.
Sizes M3 and up.
Sizes M3 and up.
Those seem a better alternative to tapering into thick aluminum sinks ... !!!
Do you have a link to the UK supplier ? Thanks ! 🙂
nAr
you don't need an extra "silpad" between the clamp bar and the FET case. Silpads and similar are conformal. They change shape at elevated temperatures. Basically they start to "flow" by going into a plastic stage to enable them to fill all the little crevices/scratches etc.I will just use silpads between the back of the fet and the bar .
This will release the force of the clamp bar.
You need springiness/compliance that is as near perfect "elastic" as you can get. Some materials "creep" with time and/or with stress. These are no good either for trying to maintain a near constant pushing force.
In the first instance just clamp the bar down onto the bare FET case. Some elastic deformation of the clamp bar and of the FET package will give a tiny bit of compliance. Even the bolts stretch slightly when tightened = more compliance.
Helicoil are often used to "repair" damaged threads.Have you tried Helicoil inserts. Possibly easier and more reliable solution for stripped threads.
A better use for Helicoil is to make the original helicoiled for all tapped holes.
Then you can remove and replace studs/bolts with ease and almost guarantee never damaging the thread.
I have a couple of secondhand heatsinks that came with ALL the tapped holes helicoiled. It must have cost a lot to buy first time around !
Thermal!
Hi Steve,
all materials expand and contract at different rates when exposed to temp fluctuations . Straight epoxy would come loose in time . Thermally conductive adhesive would allow the heat to migrate at the pretty much the same rate as the surrounding materials.
I hope this explains a little .
Rich
Hi Steve,
Rich
Hi Jimbo,
helicoil is a good system , but I have never had a faliure with the method I described .
My method is based on what I carry in my workshop for such problems .
I work with all kinds of materials . Some epoxy is Lloyds registered . It has to be insurable. Devcon R&D is in bed with NASA ... and they dont make O rings .
Rich
Rich
Just do a search on eBay UK for "Helicoil" and the size eg. M6
A fair range of suppliers and prices will come up. I went for the Silverline kits which include the drill bit, inserts and insert tool.
My original source doesn't seem to be selling now but others there have the same kits.
nAr
this is the company I use for most of my consumables http://www.buckandhickman.com/find/keyword-is-helicoil
Rich
Rich
reduced to tears now !
rebuilt my amp and the same problem .... NO HEAT !!!!!
27.75 vdc across speaker outputs ..
Left channel + board 2.970 vdc
- board 0.000 vdc
Right channel + board 2.925 vdc
- board 2.918 vdc
- board 0.000 vdc
- board 2.918 vdc
Half Way 🙂
I have one channel working getting around 22.5 Mv across speaker terminal ... I measure across C+ and C- on the working channel and got 10.4 Mv
same measurement on the no working channel reads O....any ideas Gents ?
What did you do to get one channel working.
If you set the bias trim pot wrong that could turn it off.
Was it plus or minus on the spkr out? Watch your polarity with the meter.
- Complete Novice Needs Help
