Konzert Amp & Speakers Website
@jojo
sir what would be the cut off frequency for wsx sub and also for the mt122. on your sound system what kind of amp. you used to drive wsx? i need some help to set up my small sound system.
2 WSX powered by Phonic XP5000 Bridge at 4Ω...Xing at 90Hz using W8 for the tops.
For MT122 i know they were cross at around 125Hz...go to Speakerplan.com search for the MT122 plot.
have a nice day,
jojo
hi jojo, reliable ba ang xp5000 sa 4 ohms bridge?, i just recently purchased that amp here in UAE, i didnt tried it yet at full blast.. thanks
Hi C3P0,
So far we have not yet experience any failure from XP5000 at 4ohms load for Sub-woofer applications.
Please take note that we are using 4 WSX which are very efficient...so we easily get the required spl for a certain gig...if ever needed more spl, we just add another block of 4boxes.
Magandang araw,
jojo
sir jojo.
the mt122 do i need to bi amp it? what would be series capacitor for the compression driver im using the tdu500 konzert and any solution that to prevent comprssion coil not to burt out.
thank u sir jo
Hi rhodrich,
It will be better if you Bi-amp MT122, you have a better control. You need to have a good passive network (LC) not just a hi-pass capacitor.
Did you buy the TDU500 along with its Horn?
Magandang araw,
jojo
Hi C3P0,
Magandang araw,
jojo
thanks sir jojo, i will use the xp5000 driving 4 w-bins in stereo mode, i hope it can do, (parang bitin pa yata) driving Fane 18xb. Regarding mid tops sir, will the mt212 can compete with dual electrotec?, as of now im using MB315 kuno from music box 2 design... salamat sir
music box 2 systems electrotec
sir jojo, this is the electrotec im saying, dual and single, these boxes are not mine, but im planning to get the dual... salamat sir
thanks sir jojo.
untill know trying to finish the whole system i got 16 wsx sub , 4 mt122 and 4 yamaha sv115 but the amp used for the sub are diyamp. bec low un budget. can sudgest me jo how to tailord the sound. the necessary gudget to make it sound pleasant. used the system for mobile disco.
thanks.
sir jojo
thanks sir jojo.
thanks.
sir jojo
hi rhodrich, thats a big setup 16 WSX, that indeed very loud, what amps are you using?, most diy amps here are westrak and BGW clones, please post some pics. thanks
