Problem with NE5532 based preamp
Hey,
I made pcb using this circuit.
Pre Tone Control Stereo by IC NE5532 -Audio -Electronic Circuits Diagram-Elecpod
When I fire this thing up there is voltage difference between pins 2 and 3 ( and 5 and 6). So there is voltage in the output even there is no input at all and volume is turned to zero. When turning knobs it affects voltages. The lowest voltage is achieved when Volume is anticlockwise, Bass is in the middle and treble is fully clockwise (15mV at the output and 70mV between 5 and 6) . Even then there is BZZZ sound coming out of the speaker. My meter isn't pro one, so it might be that those readings aren't exactly right, but it gives direction.
I think there is two things which could be wrong. First is that my pcb design is not right. Second is that the schematic is wrong.
Can you see or guess what could be wrong?
You might want to put a capacitor from pin 4 to ground and from pin 8 to ground.
The Opamp might be oscillating.
Make sure that your +12 volt and -12 volt supplies are delivering clean voltage.
I once designed a circuit using 5532 IC's. I had a similar problem and discovered that my batch of IC's was bad. I temporarily installed 1458 IC's and the problem went away.
I ordered a new supply of 5532's from a different manufacturer and they were good.
Good luck.
You may well have oscillations. Neither the layout given on the same page as the schematic nor your layout are close to ideal. In particular having a long track connected to pin 2 (and pin 6) is asking for instability when an opamp is used at low gains with fairly high resistance feedback as here.
You can AC-couple the output, i. e. put a capacitor in series and a resistor to ground after that. The resistor should be in the range of 100k to 1meg. The capacitor should be chosen according to your desired high-pass filter roll-off.
Or you can look for a better schematic.
And that is what gives the trouble. The non-inverting input is directly grounded which gives 0 V offset. The inverting input may or may not have a DC path to ground, because that depends on the following amp.
If it has a path to ground (DC-coupled amp or AC-coupled plus terminating resistor before the input cap) there is a DC offset at the inverting input and its difference to the 0 V at the other input will be amplified. What makes it worse is that VR-3 and VR-4 make it variable, so even the possibility to set the DC offset at the non-inverting input to the same value with a resistor won't work well.
If the following power amp does not provide a path to ground (AC-coupled amp without terminating resistor at the input), the inverting input is floating.
Another thing that is not so nice is the possibility to short the source's output as pointed out by mjf in another thread. Volume pot fully open and balance pot to one side means direct path to ground from the corresponding input pin.
I agree that the direct grounding of the +ve input isn't ideal - a series resistor would help to reduce the offset. But that's not what the problem is that the OP is experiencing.
Incorrect. As I explained above, it has a DC path to ground via the two resistors and the pot. In fact, only a DC path is necessary, its not required to have it to ground. The 5532 is providing a DC path to one or other of the supply rails via its OPS.
It won't work perfectly, but this is audio, it will work well enough.
Yep - could be fixed with lowish (say 2k) series resistors either side of the bal pot.
No. The resistor needs a value that sets the DC offset at the non-inverting input to a similar value as on the inverting input, if you want low DC offset at the output. That means its value should nearly match the combined resistance to ground at the inverting pin at any moment. How do you match a resistance that is variable by two potentiometers with a single resistor for all possible settings?
What is it then?
You mean, we are wasting our resources on an input resistor to ground when we make amplifiers?
Maybe as long as you don't define a minimum quality requirement. The following description shows the influence of that variable DC path to ground and how it does not appear to work well at all. The word 'voltage' is used in the sense of output DC offset here.
Tone controls affect the voltage. Bass full anticlockwise and volume 0 the voltage is 3,3V. Turning also treble to full anticlockwise its 5,3V. If I turn all three knobs fully clockwise voltage is 1,8V. And when Treble and Bass are fully clockwise and volume fully anticlockwise the voltage is 0V. Sound from my test speaker is very BZZZZZZZZ even when there is that 0V from preamp.
hello.
found in an old national datasheet (lf353) a tonecontrol.
if you omit the unity gain buffer at the input and the midrange control - it is similar to schematic post one (swap lf353 to ne5532). but this schematic does not show psu decoupling caps (e.g. 100nf per rail),grounding res, et cetera..........(should be built in).
So - how low an offset do you think is needed?
If you look at the schematic carefully, you'll notice that its only the bass control which has any effect on the DC conditions - the treble pot is AC coupled. Never heard of ganged pots? I don't consider the offset changes to be a real problem here so I'm not going to suggest an extra resistance track to cope with this.
A cursory analysis shows that the impedance seen by the opamp -ve input varies between 20k and nearly 60k. So I would suggest a 39k resistor on the +ve input, bypassed by a cap of 100p. With this resistor the offset will vary by +/- 4mV in a typical case - the input bias current from memory for a 5532 is 0.2uA.
What is it then?
Posts #2,3.
Nope. How did you get that notion?
That text you quoted shows there's a problem with the OP's original implementation. If you think there's a problem with the schematic, go ahead and demonstrate that but its a very basic error to confuse the map with the territory.
Depends on the application. If the following amp is DC-coupled like many chip amps are, then the offset should be really close to zero all the time.
With an AC-coupled amp the main question is, whether the resulting offset is far enough from the rails to avoid output clipping with high signals.
Yet Makk's description tells that the treble pot has an influence on the offset.
What has the construction form of the potentiometer to do with the isue at hand?
± 4mV referenced to what? And how much offset does that give you with regards to ground, i. e. with regards to the non-inverting input?
Posts #2,3.
Funny oscillations that you can adjust with the tone controls to give variable DC offset.
Isn't that what this means?
I agree with you there and I suspect that the real problem is that a DC-coupled amp is connected to this tone control circuit.
Not with the schematic as such, but with the bad assessment of the audience the publication is aimed at.
Somebody with sufficient technical background to make it work by introducing resistors at either side of the balance pot and adding AC-coupling to the output does not need that schematic, because he could devise one on his own. For all others these measures should either be shown in the schematic and included on the PCB or they should at least be mentioned in the accompanying text.
All of which is fine, but avoids the question - which if you remember was 'how low an offset do you think is needed?'. Make the call - put up some hard numbers.
Doesn't that tell you something? Don't you get the hint from that piece of evidence that the offset might not be being caused by bias currents?
The issue at hand in this case was your earlier question. Which if you don't recall it, was "How do you match a resistance that is variable by two potentiometers with a single resistor for all possible settings?". The answer to it, once I removed the fallacy that there are two relevant pot settings, is 'with another variable resistance which tracks that variable resistance'. Any clearer now?
To the input, as offsets tend to be traditionally specified wrt inputs.
I'll leave that as an exercise for the interested reader to determine. Note that since I have suggested a series resistor in the non-inverting input, its no longer at ground potential.
Yep. Why do you think they're funny?
For the second time, no its not what that means.😀
Given that you've got this as a hypothesis, how are you going to test it?
Various flaws in that reasoning. The first is - it works without the resistors either side of the bal pot. Second is that AC coupling the output is not necessary to make it work. I'll stop at two.🙂
Why should I? Are you feeling that this is a competition of some kind? If so, what is the prize for debugging somebody else's bad design?
There sure are more flaws than just one. The one caused by the bias currents is sufficient for me to discard this tone control for use with a DC-coupled output. Until the output is AC-coupled any further investigation is a waste of time (to me).
I just simulated the circuit and depending on the pot settings the output offset varies from 9 to 32 mV. With the 39k resistor you proposed it varies from -9 to 13,4 mV. With a 100k pot ganged to the bass control pot it varies from 9,3 to 15,5 mV. I see no way around AC-coupling the output.
Different country, different tradition. Where I live offsets are traditionally referenced to ground.
Also note that the suggested resistor is a modification that requires a different PCB. Does that mean you agree that the original schematic is not optimal?
Why don't you?
So what does it mean?
The search function on Makk's posts turns up the following.
And the kit is LM3886 from the chipamp.com.
If Makk has not modified the kit, he owns a DC-coupled chip amp with a gain of 33,35.
I'd rather not call it flaws, but different demands. A tone control where you have to avoid certain combinations of pot settings may be good enough for you. I would not accept that for me. Neither would I expect anybody else to do that.
DC-coupling the unmodified tone control to Makk's amplifier leads to a DC offset at the speaker terminals between 0,3 and 1,07 V depending on the pot settings without taking into account what DC offset will be added by the power amp itself. Good enough for you? Unacceptable for me.
Why should I?
Oh, how funny! How many more irrelevancies are going to be introduced to this thread which is about a single opamp schematic? I'm neither your mother nor your boss, just another diyer so 'should' does not enter in any way. I simply gave a request, an invitation. You've declined the invitation, that's fine by me😀
In answer to your first question, no, clearly this is not a competition. But since you've raised the topic its clear you're feeling it is. I propose to terminate my own involvement in the discussion as I prefer cooperation myself.😀
