My Dream Aleph 2 Coming True
Which end of the zener connects to the positive rail? Should be the cathode (band)
What is the resistance from the zener anode to ground or negative rail, depending on which you use?
What is the voltage between the CCS mosfet Source and the positive rail?
We're trying to be sure the CCS is working before we worry about the differential pair.
Measure the voltage referenced to ground at both ends of the zener, all three pins of the CCS IRF9610
What is the resistance from the zener anode to ground or negative rail, depending on which you use?[wiki=]%[/wiki]
Yes, Cathode. The resistance was 0.00 . I was measuring from source point to +Vcc 0.9 going down and when reach 0.4-0.5 after more or less 5 mins started reading 283mv.
Let's get them all in one post, please.
Also measure across R12.
Post a picture of the bottom of your board. I suspect a solder bridge G-D on Q3
Also, please post rail voltages.
So, we need:
Rails
R11 = 0 Should be ~5
R12 should be 0
R13 should be rail -9.1
R14 should be ~4V
Guess I should have specified a picture of your assembled board.
R13 - is that top to ground? Something is wrong there - the junction of R13 and Z5 should be 15V above ground. With power off, measure the value of R13.
Are the rails symmetric - +/- 24V?
So your CCS isn't working. Replace the zener with another. Then we'll have to look at Q3.
