Man, fall is beautiful (last PIX) .. the "Doghouse" is in a monster tree forest... 🙂
OS
1. Cover up speaker with a bit of camo and pile on some leaves.
2. Run some wires to amp and put on spooky sounds such as things growling or moaning.
3. Scare the dirt out of little trick or treater's 😱
WARNING - if Mama finds speaker you can kiss it good-bye!
If Mama finds you - RUN!!!!!
Yeah , C2 , I have a sony speaker up in the tree runnin' on the big mongrel. They don't know where it's comin' from... Scarrry...
Those trees are like out of the "headless horseman" story.Older too (500 years) BOO!
OS
OS
Is there any simple way to clamp outputs to a heatsink using ordinary household materials?
if you use alu bars, or similar, you could use ordinary metal screws, and do without other tricky tools
just dont mount through the devices, but place the screws beside them
try on a small piece of alu first, to see how big the holes need to be for the chosen screws
its important not to break a screw
or it could also get stuck halfway, with a damaged head
torx screws might be the better choise
btw, drilling and tapping in aluminium is best done using household spirit, and plenty of it
dip the drill or tap into the spirit
and be very careful
those small drills and taps breaks very easily
and the bits will sit in the alu forever
slowly drilling
and the tapping is carefully back and forth, bit by bit
and by hand, it takes practice to get it perfectly straight
and remember to carfully level the surface afterwards
wont hurt to level the back of devices too
hold it up against the light, and its easy to see how it is
I prefer to counter-sink the pilot hole prior to tapping. This prevents the first few threads from being damaged, which is what will happen when you counter-sink after the tapping process. Lots of kerosene with some motor oil is a good lubricant for tapping aluminium.
PCB file for the PB120LP v2.0
Hi OS,
I have incorporated all the improvements that you suggested earlier. I put together the PDF file for the PB120LP.
Can you please put the attached file onto your web site as this version is an improved version of the PB120LP-45V.
Cheers, Stanley
Hi OS,
Cheers, Stanley
Hi OS,
Cheers, Stanley
VERY nice. It's on my site. I DL'ed KICAD. All you do is draw out schema and it makes the board?? how do you import new components into the library. I have a lot to learn.
Below is new creation (BX) to add to "collection"
OS
OS
Hold on a sec, I will send you the link for new parts that you will need, I found it just yesterday.
http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm
READ the post before putting them in your system... a little tricky, need to remove before installing.
Looks good.
Looks good.
EX .. LEECH meets hawksford
Thanks a lot, Krisfr .. that is a lot of 3D "candy". I actually like that the library is generic since I do this primitively anyways. 😎
I HAVE decided , my november amp will be a fully complimentary design. The EX (attachment 1) has the FASTEST slew of them all (way above 120 V/us). That might not matter .. but what the hell !!! I am using a modified Hawksford similar to my GX but it has a beta enhancement feature like was discussed in the goldmund threads. It can be thought of as 2 very fast "BLAMELESS" amplifiers symmetrically opposed. It is very linear , LOW THD ... .0005% 1k / .008% THD20 @40v p-p.
It is below in LT form , too. Not too many leech type projects around here , why not create one.. a BETTER one. 🙂
OS
OS
My PB250 has the resistor pads for a passive EF3 , so I can still do that. The EF2 is flawless in a high negative feedback power amp. The only 2 situations where a triple or CFP would be needed would be for many outputs or a non-switching AB setup. I experimented and implemented a EF 3 in my "trouble with triples" thread to augment the performance of the triple.
The sound quality I hear now with the luxman/hawksford is close to absolute perfection. My only purpose to build the EX is that it is the "better"luxman (more expensive and is a lateral OPS amp. My EX could do almost 200v/us , so I'm curious ... and it's just going to cost me another $20 , thats all. The CSS EF's do sound a little "tighter" with drums but this can be compensated witha better faster voltage stage.
OS
PS: by next year ,I should be up to a "ZX" or close to it. Then I will do a subjective / objective "shootout" between all these class AB designs. I am trying to find an analyzer (real one).
OS
OS,
You could replace the differentials with a comp, pair and take the feedback to the sources and have a decent gain in bandwith.
Something like I designed here but I would keep the VAS cascoged like you have
Jam
Jam
OS,
Jam
Where are the transistors ??
EX- 75 X 100mm and FX- 100 X 100mm board.
OS
OS,
I also ment to say replace the front end Mosfets with bipolars, Sorry I did not mean to put you into shock. 😀
The output stage would be up to you. I ran the original VAS (mosfet) at 40 mls.
Jam
P.S. In my younger days I put Mosfets everywhere..........😱
Jam
OH ...yeahhh. FX it is. .003% THD20 in all it's "fet glory".. 😎 (below) FET's at 3.05ma each...
PS - I notice it takes a lot less current swing for the N-channel FET's than the P- channels , BJT p-n pairs are MUCH closer (ksa/c's)
(attachment 2)
OS
(attachment 2)
OS
Looking good OS......so much for the simple approach.😀
How about replacing R20 and R21 with current sources for good measure.😉
Jam
Jam
they are CCS's , they feed D3/4 (RED led CCS's) !!Looking good OS......so much for the simple approach.😀
Jam
Yes, but when you replace R20 and R21 with current sources (or current diodes) you improve the performance of of the original current sources by about 20dB, I believe. Something to do with better rejection of the rails.....
Jam
Jam
Yes, but when you replace R20 and R21 with current sources you improve the performance of of the original current sources by about 20dB, I believe. Something to do with better rejection of the rails.....
Jam
But my rails are "squeaky clean" , either cap multipliers or full blown shunted separates , so this would not matter. A simple improvement would be the 2 device style CCS for those without these "enhancements". In reality , I get about 5-10mv ripple when slamming my current GX w/multipliers. Sounds like a dual monoblock.
OS
- The MONGREL (supersym II)
