you bet!
Italian dream ....... same as ZM's dream
even if I like Guzzi more![]()
You talk with an ancient owner of a v35 imola
Preamp
Hello,
My almost finished preamp combining aleph P1.7 and 2 stages of a X-ono, just tested with my integrated yamaha amp at this stage. I think I can't measure the quality of the preamp in this set-up, but at least I can say that the phono section is far better than the one included in the yamaha.
Now this preamp misses an amp... and some tuning, mainly to get rid of the radiations of the toroids on the phono pre (the sheet of steel just between the 2 cases that can be seen on the picture helps but is not enought).
A great thank you to Nelson for sharing his knowledge.
And also thank you to all hobbyists who inspired me, they may recognized some of their ideas in my preamp.
Hello,
perfect nick , wooden amp , v35 ........
my man !
btw. today's 11-th to 1-th ........ one of most impressive , all away from days of 125;
pity rest of the field just isn't up to task of real racing
yes, I agree
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
anto
I didn't tryd that they get way to hot so I changed them for coils.Wery nice work Rob .Is any audibile change between changing resistor with coils in power supply?
They where 0,11 Ohm with 9A current.
I only draw the layout and a friend makes it in his shop with a cnc machine also the top bottom and back plate.dear Rob,
How did you get that kind of front made?
are you an industrial designer?
Rob
Hi Androuski
Heatsinks were bought here:
>> GoriniSRL Main Page << Dissipatori di Calore in Alluminio
Ciao
Thank you 10y
Enjoy your listenings
Thank you 10y
![cloud9 :cloud9: :cloud9:](https://files.diyaudio.com/forums/images/smilies/cloud9.gif)
have you found gorini's prices cheap?
I just completed another Jfet Delite Amp.
It's both a light fixture and an amplifier and I like the baltic birch enclosure.
finally finished the F5 with remote PS. tung-oiled sapele wood. pictured below the F5 is the B1.
[/IMG]
http://i23.photobucket.com/albums/b353/fishski13/F5/IMG_5556.jpg
http://i23.photobucket.com/albums/b353/fishski13/F5/IMG_5492.jpg
and the B1:
http://i23.photobucket.com/albums/b353/fishski13/B1/001.jpg
http://i23.photobucket.com/albums/b353/fishski13/B1/010.jpg
![IMG_5577.jpg](/community/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttps%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb353%2Ffishski13%2FF5%2FIMG_5577.jpg&hash=8125d6c8ecd52d37705f43cbf5c92117)
and the B1:
Beautiful builds!
What are you using for speakers?
[/IMG]![]()
and the B1:
Beautiful builds!
thanks. a pair of uFonken^2 with 2 Fostex FF85K drivers per side.
http://i23.photobucket.com/albums/b353/fishski13/uFonken2/016.jpg
i always loved solid wood combination with metals
i envy urs.
looks like ur f5 using some good components there.
u left the top open all the time?
cheers
henry
yes, no cover on the amp. while initially "hot", i can hold my hands on the heatsinks indefinitely with 1.3A bias.
- Pictures of your diy Pass amplifier
