Salas low shunt Group-design by Salas
1. wendell c : 3 set : $48
2. andRookie : 3 set : $48
3. df_genius : 4 set : $64
3. sandbasser : 4 set : $64
5. daanve : 2 set : $34
6. barmanekm: 1 set : $18
7. ksnider1: 2 set : $34
8. mace1337: 3 set : $48
9. CeeVee: 3 set : $48
10. merlin el mago: 2 set : $34
11. Westley : 4 set : $64
12. Groundloops: 4 set : $64
13. Ciu : 4 set : $64
14. fitzfish : 4 set : $64
15. ClaveFremen : 2 set : $34
16. Ramallo : 1 set : $18
17. number9: 2 set : $34
18. frozen wing 2 set :$34
19. bracla: 3 set : $48
20. Globulator: 1 set : $18
21. korben69 : 2 set : $34
22. analogdiy : 4 set : $64
23. rickmcinnis : 1 set: $18.00
24. guglielmope : 3 set: $48.00
25. suburra : 1 set : $18.00
26. h-wan: 3 set: $48.00
27. hawall841 2 set :$34
28. VT67: 2 set : $34
29. qusp: 2 sets : $34
30. awpagan: 2 sets : $34
31. joemana : 2 sets : $34
32. gorko1 : 2 sets : $34
33. marcus1: 3 sets: $48
34. Ryssen 3sets 48$
35. drazen : 2 set : $34.00
36. stephen1212 : 3 sets : $48
37. claudio: 1 set : $18
38. TheShaman: 10 sets: $160
39. Slartibartfasst: 2 sets: $34
40. Carrier Bag Man : 1 set : $18
41. prooptiki : 2 sets : $34
42. Andrew T. 10sets
43. JimT : 2 sets : $34
44. Nikon1975: 2 sets : 34 $
45. sureshm : 1 set : $18.00
Total: 122
I am in.
I would like two sets.
46. barrows: 2 sets: $34
Total: 124
Thanks for all the work on this!
@Quanghao
Setting current 400mA needs a big heatsink or direct to chassis so mosfets layout must be placed laterally like Hypnotize PCBs
This is layout for Salas low shunt, Have 4 PCB one board
I updat , you can use big heatsink -TO2
for need more 400mA.
please see it, and advance for me! Thanks
@Quanghao
Can I use these?
ABL HEATSINKS|345AB1000B|HEAT SINK, 1°C/W | Farnell España
HEAT SINK, 1°C/W
Thermal Resistance:1°C/W
External Width:120mm
Height:37mm
Heatsink Material:Aluminium
External Depth:100mm
External Length / Height:37mm
Material:Aluminium
Surface Finish:Black Anodised
External Height:37mm
Length:100mm
One set for me please.
47. jonners: 1 set: $18
Total: 124
Thanks!
Snap in
Quanhao-
Thanks for all your work on this project. Are the PCB holes for the filter cap big enough for snap in Cap legs? They should be able to accommodate snap ins for the values that some will use. I am thinking 3300-4400 uF Nichicon KG and Mundorf M-lytics.
PCB plans to make and send
1. Information Salas Shunt regulator module for Clock, DAC, Phono, Pre:
Out put from +1.5V to + 35V One PCB * 4 supply*
1. 1 x voltage + 5Vout to + 35Vout
2. 1 x voltage + 5Vout to + 35Vout
3. 1 voltage -5Vout to -35Vout
4. 1 x voltage + 1.5Vout to + 5Vout
One set : You can split into three separate PCB
2. The price includes:
1. One Set + Worldwide shipping + paypal fee = 18 $/ One Set 2 . Tow set + Worldwide shipping + paypal fee = 34 $ / 2 Sets 3. Over 3 set.....+ Worldwide shipping + paypal fee = 16 $/ one Set
3. PCB plans to make and send
I have completed the perfect layout for low shunt Salas.
So you send me money starting from 9-10 to 15-10-2010.
I started to put the PCB 16 -10-2010. Estimated 27 -10-2010 I will send to all your PCB.
4. Shipping from Vietnam: (surface mail)
Ordering:
pls sent me a PM with the following information:
Forum ID:
Real Name:
Shipping address:
Paypal account email:
The list of items, the quantity, and options
Your phone number: ( it is very important for you get PCB)
Payment:
my papal: quanghao168@yahoo.com.vn
Shipping:
Shipment by Vietnam Post International Registered mail
T?ng công ty B?u chính Vi?t Nam > Trang ch?
Thank you very much!
Quanghao
As a schematics draft looks OK now, the first reg's Rset table using a BJT in CCS is misleading though. 10R=65mA 5.6R=116mA 3R3=197mA 1R8=361mA, copy that there. The other tables for regs using LEDS are ballpark OK for tolerances. I mentioned that before. I also maintained in previous posts that there must be a prototype full test even though V1 is generally proven trusty to work easily in most layouts. Its common practice to make a prova generale. I can't repeat it more I guess. I had obligation to review the theoretical draft since it carries my design frames, but practical layout and testing stuff is your obligation to be followed in serious fashion and ensure success.
