DC Servo MOSFET Amplifier
RE Replacements for IRF240/IRF9240
IRF640/IRF9640 or IRF540/IRF9540 (with +/-45V DC max rail voltage) can be used.
Hi Apex,
I found IRF540/IRF9540 fets. I have a +/-49V DC transformer with me. Can I use this transformer or is +/-45V the absolute max voltage for this amp with this fets. If so I will then continue my search for the proper fets. Any mods I can do to use this fets with my voltage?
Macd🙂🙂🙂
Hi Apex,
Macd🙂🙂🙂
What is AC voltage on transformer? You can use IRF540/IRF9540 with +/-49V DC rail voltage for usual home listening.
+-49Vdc from a 35+35Vac transformer seems a bit low.
Is the transformer 230:35+35Vac?
Is your supply 220Vac when you measure the rectified DC voltage?
Are you using a single bridge rectifier with a CT transformer, or are you using dual bridge rectifiers with dual secondaries?
Yes, the transformer is rated at 220:35+35Vac. I am using a single bridge rectifier with my transformer. Only one secondary. I have measured my DC volts on output of transformer. +/-49V DC.
Macd
Stcboy's F100
Forum member do simulation of new DC Servo Mosfet Amp, after correct some mistakes on schematic. I must design PCB for this Amp or someone else do that🙂
Apex seems i begin to love this amp 😀...the corrected clear schematic is this...
with different R14 values(tried 22k,30k,56k) and different supply voltage, circuit gave 50W-200W on 8ohm with great frequency response....
i try now to use opamp at front-end for smaller and simpliest pcb....
i tried many opamps so far (opa637,tl072....) but only the NE5532 gave a good result...60W/8Ohm
using +-50 supply and 30k(R14) on feedback...
i 'm not an expert on opamps so,any idea which other opamps to try?
the circuit i try is this....
is there something that im missing?also the sine is not clear at output...seems to have much distortion...
oops....forgot it.....once more thanks for help...
fixed & worked
i changed values on R14 & R28 for ~110W/8Ohms
sine
the frequency response wants a fix....and you know i got 110W at 1Khz...
