New DHT heater
This is a big red flag for me - I'd like to use them with 6C4C, but I'm wondering whether your approach has enough design margin with respect to the parts used. I want to know that the amplifier is repairable in the future without being reliant on hard to find parts (except the bottles of course!) ???
Then stick with AC. This is a cutting edge design and not meant for a one time amp builder. Rod is pushing the envelope and I appreciate his approach.
Rod ...
I am running 75TL and stuff like this ... they call for 6.25A@5V. I'd love to make a back-to-back test with my LCLCL filament supply. A bit too much maybe?
Gianluca
Gianluca, I think it will be possible, but some extra precautions are needed:
- the heatsinking must be very large, about 0.7K/W
- DC supply must be 10,0V +/- 1V
- I must make some small component changes.
I'll try it when I can.
Bigun, the transistors are important, but I have now identified 5 or more parts that meet the requirements. I list these out when the tests on them are done.
Also, I plan to buy large stocks of parts, and will sell transistors to any that may want extras for spare parts. I'll try to keep enough stock to satisfy any repair needs that may arise.
Thankyou, several of us plan on trying this heater will highl sensitive headphones so obviously don't want to trade performance for convenience.
OK, 845 (3.3A 10V) will be a standard kit, available soon.
For indirectly heated valves like the EL34 and 6SN7, there will be a standard kit to suit them -although the performance upgrade compared to ac heating is not as big as it is with the Directly Heated triodes & pentodes.
Right now, I'm working through the different kits, and evaluating the performance and power supply requirements for each design. Then, I'll finalise the parts lists and kit contents, and have the prices ready - very near now.
2a3
Here's a completed heater for a 2A3! Low noise performance for 7V +/-10% input supply.
Hi - on vacation for a few days, but some progress to report:
So far we have the 250mA, 250mA/#26 switchable, 300B, and 2A3 versions all characterised. They are working well - with sub mA ripple in 3A versions, even with 200mV input ripple voltage. Voltage headroom required is 4V minimum for sure, less typically. The GM70 version [20V 3A] has taken some time to get under control, due to the big switch-ON power pulse in the power transistors. (That's to say - the first versions failed due to overstress from the 24..25V-supply needed in these transmitting tube filaments). I wanted to have all the versions ready at once, as I believe many folks want the GM70 along with orders for the lower power heaters.
Meanwhile, the documentation in terms of assembly guides, power supply build examples, heatsinking worked examples is advanced but not complete. It's been quite an effort to prepare all these! Hoping to have a big finishing effort when I get back, and on with the release - I have plenty of PCBs stocked.
Apologies for the wait - I intend to offer a well-documented, well-supported offering, - thoroughly tested by the time it is released.
Rod
