OLD THREAD DAC End by Andrea Ciuffoli
I have a couple of questions for those who have finished the DAC.
Did anyone try removing the filter (L1,L2 in the DAC and R30-33 in the IVY)? What difference should I expect if I do that?
Also, I'm thinking of switching some caps to Black Gate. The ones I'm replacing are the Sanyo 47uf. I'm having the OSCON SP there and might try the BG NX HiQ 47uf. Other caps are the 220uf in the IVY. Thinking of popping the BG N 100uf into there. What do you guys think about this? Is it worth replacing those caps?
Help
HELP
Problem with Salas HV
Using 0-250 Rcore -260V AC at input
250VDC after rectifier?
Have blown 2 9610s
THe 470 ohm resistors start smoking after 2 seconds. Obviously too much current
No obvious shorts on board.
Where do I start troubleshooting
Bob
HELP
Have blown 2 9610s
Bob
You see this image
What about the Led??
May be Mje 350 died , so 840 get all mA
QuangHao:
Thanks for the reply.
I have the IV and Salas HV board which I am building to power the E182CC IV board.
I will check the MJE 350.
The 3 LEDs light.
R1 (33 ohms) is also very hot so it draws excess current.
Oh. I don't have a 1N3838 installed. Did not see it on the BOM. Will try to find one in my parts.
Best
Bob
Per Quanghao I will not use the diode across the 9610.
I found out that my 47 ohm resistors were 470 ohms not 47. They are marked 47. This happened to a fellow DIYer a couple of years ago. I usually check with a meter before installing but became impatient. Live and learn. I have replaced semiconductors and will see how things go later tonight.
