"a thread dedicated to our great dr bora"
everybody this is sekhar from INDIA (WB). This thread is dedicated to our great "Dr Bora" also known as "boraomega" in the forum .This thread is specifically dedicated to the great amps built by "Dr Bora".
It is a salute to his great contribution to the diyers . It is welcome note to all the people who has already built his amps or willing to built his amp .it will be a common platform for all the fans of Dr Bora & his amps.
I personally have made two of his amps
1. LEGEND STAGE MKII
2. STUDIO SE
Both of the amps r a master piece in it self .
Every body who has built Dr Bora's amps r requested to post their reviews and pictures .
their r many amps in this this forum that r liked and built by many diyers .Dr bora's amps does nt seem to be one of them as they r nt brought in light to the diyers . I will try my best to provide all the details of the amps built by dr bora of course with his due permission.
for a start I will provide the list of amps by dr bora.
1. CALOR- gold(CLASS A 40W)
2. Standard (50-60W RMS/8 ohm)
3. Lambda (100W RMS/8 ohm)
4. Legend(125W/8 ohm)
a.LEGEND-Stage Master(250W RMS/8 ohm )
b.LEGEND-Stage Master MK2(500W RMS/8 ohm)
c.LEGEND-QUASOR(1000W RMS/4 ohm)
5.Modus (aka Techno)
6.DOGC-MK3
7.Studio
8.STUDIO SE(80E RMS/8 ohm)
9.Epsilon(100-120W RMS/8 ohm)
10.Sigma
11.SubZero
12.CroSer( 100W RMS/8 ohm)
13.T-Reference
14.Goliath
15.Universal
16.Blaster
ALL OF THEM R VERY GOOD AMPS NO BODY HAS PUT SO MUCH EFFORT FOR DIYERS . HATS OF TO U DR BORA .
WILL PROVIDE MORE DETAIL LATER .....
DR BORA'S WEBSITE :- bas.elitesecurity.org
REGARDS
SEKHAR
SOME OF DR BORA'S AMPS BUILT BY ME :-
Dr. Bora is not a selfpromoting man, therefore everyone are not familiar with his designs. He is truly a wonderfull person and perhaps it's our duty (us who have built any of Dr.Bora's projects) to get to world introduced to his designs. These are some of mine:
DoGC mk3
Studio
Tehno aka Modus - a good friend of mine refuses to give it back to me 🙂
Clepsidra preamp
Flat BTpreamp
I have to mention the the list of amplifiers provided ba sekhar is not even close to a full list of Dr. Bora's amplifiers. There is a number of hiend amps non listed in the website, but you have to contact Dr. Bora personally to get the stuff. I'm glad to say that Dr.Bora provided the material for Talisman Audio Grade ampllifier and i'm working on it.
Dr.Bora's......designs
and some of mine 🙂
Thanks to all of you people! I am truly flattered and honored with this thread and all your posts. As Zikinho already mentioned, I am not of a “self-promoting” designers and I am rarely willing to give any kind of ranking of my designs. Other people should write about that, not me. Those designs already published on my site are FREE for personal use but that is just a part of my designs…
@ andrewlebon
I will suggest Legend Quazor (not Quasar !) as better option Andrew.
Special greetings and friendly hug for Carlos! First of all that man posses a glorious personality and is very experienced designer and builder, so praise from him is carrying a specific weight and I respect that!
A good friend of mine refuses to return Tehno i've made recently and leaves me with no other choice but to assemble another one for myself. I started assembling Modus M using only one pair of output transistors. Thus, the pcb is smaller, good job by dr. Bora again.
@ andrewlebon
that amp looks like a monster, and tempting
to use seperate supply(double), is it possible to remove diodes in supply rails between frontend and output stage
I can manage 55Vdc for output stage, and 60Vdc for frontend
and maybe just use 2x 3+3 IRFP240, instead of 2x 4+4
Of course "tinitus" you can omit those diodes and supply pre-stages from separate (preferably well stabilized) PSU and provide second separate high power DC source for output stage. Your voltages should be OK but you have to be aware of significantly reduced output power on 8ohms loads. On the other hand, number of output devices and those planed voltages will give you freedom to connect loads of much lower impedance - even 2ohms should still be safe. With such a low supply, requirements for some components will be much relaxed and many replacements will work satisfactory.
whr r other people ???????????????/............. many have built dr bora's design..... victor ur input is highly recommended..
regards
sekhar
Hi sekhar! What's up?!
Annual vacations are in progress, and because that there are only few people on the forums. Do you have a higher quality photo of studio-SE amplifier? Have you tested this amplifier? What transistors did you use?
that is great, thanks Bora :cheerful:
seems I may be facing a first time making my own boards, and hardwired outputs 🙄
hey, I see now that your actual board layout is different from what you show in the first seen picture, and much nicer looking, yeah :scratch2:
hmm, my heatsinks are still 400(L)x300(W)x40, of which I have two
Instead of cutting them into 4, I could use them as is, and your Legend Quasor boards would fit nicely
But I also like the idea of placing supply caps along the output dvices, and closer
decitions decitions 😕 :h_ache:
but those boards looks good
We are lucky to have people alike Borivoje Jagodic in our forum
not only happy but deeply honored is what i fell.
I use to say, to people in my place, that i am his friend, that he send me messages from time to time...that he even answer some of my messages.
hehehehe... This promotes me a lot...you do not imagine the respect they look at me.
The man is an Engineer, a skilled one, not a young engineer, a senior one!... with expertise and passion for audio, the man is a College teacher... anything can be better than that!
Lucky... very lucky we are.
regards,
Carlos
every mosfet (240) is fed or sunk via 0r22 source resistor from the +ve or -ve supply rails.
Why have split supply rails fed from both ends of the PCB? The resistance of the traces should be small in comparison to the 0r22
If the right hand end +ve & -ve are deleted, but you keep the output trace spkr tab at the right hand end, you will ifnd that the total trace resistance from +ve to output and from -ve to output is near identical for all mosfets. It's the same as a water radiator connected "tboe" (Top and bottom at Opposite Ends).
