500W PA amplifier with Limiter
can we see the pic of the transformer
apex
sir,
i bought all the b500 components...i noticed that some components in the schematic differ from the pcb placement guide...
i need to know which one to follow...should i follow the schema or the pcb???...im using two psu for testing 1 is 50 0 50vac @20amps 2nd is 55 0 55vac @25amps...
tnx...
regards...
why do need such amp rating for ur transformer........ can we have a look at the pictures of ur transformer
regards
sekhar
regards
sekhar[/QUOT
i once built an amp with this psu rating with EI core...i thought of using it again...
dc on output
apex...
sir... i powered on my b500 circuit...
i had dc on output about 7v...
i put 2 330ohms 10watts resistor on xformer primary...
power trannies seemed to warm up...but dc occur on output...hum on spkr...no audio on output...
what seem to be the problem???...
pls help...
tnx...
regards...
apex...
pls help...
tnx...
regards...
Do not connect speakers if you have DC on output. If you not forget to connect wire jumper (red line) on botom side of pcb or GND on input with separate wire from PSU, try to measurment voltage on point as I suggest,
Post some pictures if you can.
Look at GND wiring.
What voltage are you using for this amplifier?
i took pics this morning
i used my fon to capture images
i guess its not that clear...
