Saba/K+H (Klein & Hummel) Telewatt TS-100 A uses RCA 2N2147
very interesting - thank you for this advices. Also supplement to post #8 from this thread.
Can you post the last site (49) separately as PDF in higher resolution?
Here some additional pics of this device in better resolutiom from German ebay auction, item No 230479417592:
Hello,
for those who can read some Italian, I'd like to attach an article I've written some time ago about it, on an old radio magazine named "Antique Radio Magazine".
Cheers
Thank you TiefBass,
I don't have a true TS100 schematic, BUT a TS100 is identical to a TS90 (schematic attached) with a different output stage (section attached) and a higher PS voltage (45 V instead of 32 V)
Cheers
Cheers
Best thanks for this schematic. About post #66, #36 and #40 there are also amp models with RCA's germanium power devices 2N2147 and 2N2148.Thank you TiefBass,
Cheers
But the TS-90A (TS 90 A TS90A TS90) is also an interest amplifier
EICO Series "Cortina"
This devices actally must be Eico's first solid state amplifier/receiver versions. There are no schematics to find.
yes, because I have filed this by post #54 and #80 aboutI may be wrong, but I haven't seen mentioned what seems to be the first Stereo Quasi Complementary amplifier ...
http://www.diyaudio.com/forums/soli...-models-quasi-complementary-power-output.html
have a look also to post #1 here
National Panasonic SG 999
May I add this japanese music center with disappearing turntable.
This set has an EV-like output stage and all germanium transistors. Nice looks but, unfortunately, it's been laid out very badly and it's a real PITA to work on, components are nearly impossible to repair.
TiefBass, you seem to have a very nice collection, it would be nice to meet you ...
The showed device collection isn't from me.
If I had this collection (along with those from in post #1 mentioned thread's), I would have one of the world's largest collections.
Unfortunately, the devices are not shown my own collection, but from my virtual photo collection, which I has stored over the years in my computer disc.
If the overview is big enough, I can make better a decision, which components I would like to have.
What means "EV-like" maybe "Electro Voice" like? what is a "real PITA"?
The "SG-999A" isn't difficult to repair, if no mechanical stuff (like tonarm) is damaged. What is exact your error description? You mention "components are nearly impossible to repair". Which component?
BTW - Thanks for the photo and schematic. There isn't to find online.
Radiola AG-9052 (Philips)
The Radiola AG-9052 (AG9052) I have found by chance. Unfortunately no schematic diagram. In use four TO-3 germanium power devices (see attached photos)
Solid State Integrated Amplifier from Cabasse - who knows the Model?
This solid state integrated amplifier from Cabasse I have also found by chance. It is equipped with germanium power devices. Perhaps it was the first solid state amp from this brand. Schematic and model No wanted.
Very special for that time is the dual monaural Baxandall equalizer unit so as the icon for the balance regulator. This amp haven't to do with that one from last (third) advertisement photo.
Yes, AD149 germanium transistors and a interstage transforme, provide them with out of phase signals. Connecting the load via a 400 uF electrolytic capacitor, inserted in the overall feedback loop...
Tandberg Huldra 8, Huldra 9 and Huldra 10
Tandberg Huldra 8 until Huldra 10
Huldra 8 was Tandbergs first receiver with a germanium solid state (transistorized) power amplifier unit
Huldra 9 uses tubes only for the IF stages
Huldra 10 was Tandberg's first "all silicon" solid state receiver
some URLs:
• Se emne - Tandberg Huldra 9.. 15 Watt kontra 25 Watt utgangseffekt.
• Se emne - Diverse!
Tandberg
tandberg
Tandberg, Tandberg HiFi, Tandberg audio, Tandberg Receiver, Tandberg Tonbandmaschinen, Tandberg open reel deck
LA6NCA, Radio transmitters and receivers from the 1940's
some URLs:
Tandberg
tandberg
Hallo! I need your help to find a spare part of National SG 999 turntable. All works but the turntable cartidge It seems to be damage, I think is not a stylus problem. What should I do? Is possible to change all cartidge component? With what?
Many thanks!
PS Thanks for the circuit diagram
Many thanks!
In post #4 you show a picture of an RCA transistor with the number 39414. It is not a germanium device. It is a silicon NPN very similar to the 2N3055. I bought a box full of them in 1969 from a surplus store in Miami. They were from a military auction. I Still have some of them and they have the exact same lot and date codes as the part in your picture. I used them to make audio amplifiers from 1969 to about 1980 when better devices became cheap.
I also have an old Voxson HR 213 receiver that was made in Italy around 1970. It is a 20 WPC receiver covering the FM broadcast band only. It used a Germanium PNP and a Silicon NPN output transistor paired in a true complementary symmetry output configuration. It also had a Jfet in the FM tuner. The unit is very small so that heat related failures were common. The units sounded very nice when they worked.
The Radiola amp is probably the same as Philips 22GH925.
Service manual here:
Welcome to www.oudio.nl !
start a thead about the German forumHallo! I need your help to find a spare part of National SG 999 turntable. All works but the turntable cartidge It seems to be damage, I think is not a stylus problem. What should I do? Is possible to change all cartidge component? With what?
Many thanks!
Startseite - Analog-Forum
Thank you for this advice.The Radiola amp is probably the same as Philips 22GH925.
very interesting - thank you very much for your advices.In post #4 you show a picture of an RCA transistor with the number 39414. It is not a germanium device. It is a silicon NPN very similar to the 2N3055. I bought a box full of them in 1969 from a surplus store in Miami. They were from a military auction. I Still have some of them and they have the exact same lot and date codes as the part in your picture. I used them to make audio amplifiers from 1969 to about 1980 when better devices became cheap.
by post #31-34 about
http://www.diyaudio.com/forums/parts/167680-vintage-transistors-4.html
you will find some cover pictures of vintage RCA databooks.
in which of them I will find the data sheet of the 39414?
Hello Darkhouse,Good Job,tiefbassuebertr:
Thanks for your Post,very interesting things I have ever met.
Go on yours,good luck!
I need translation help from an expert living in China concerning hologram lasers LTOH30PA/LT0H30PA for CDM12.4 and CDpro.
Perhaps you can give me appropriate advices.
go therefore to post #8 about
http://www.diyaudio.com/forums/digi...lt0h30pa-inside-philips-cdm12-vam12-mech.html
the original thread in your language (with various pictures) I have found about
www.diyplus.net/phpBB3/viewtopic.php?f=3&t=576&start=40
http_www_diyplus.net/phpBB3/viewtopic.php?f=3&t=576&start=40
This is clearly a "rebranded" Philips product!
Gerhard
- Overview of Brands and Models from first Solid State Audio Amplifier Components want
