KSA50 AMP(New production Live in...)
Hi gxcnabin, what is a Huitie ? Thank you for the explanation, good luck with building a KSA50. IMO it is a device from an era that is over. I really wonder if anyone compared a well built class T amp with these class A monsters. If anyone can point me to such a comparison I would be glad. I found this comparison with some other famous amps:
Clash of some Titans
BTW do you have PCB's for the tube preamp you posted some pages back ? Can you post a picture ?
Hi Jean-paul,
“Huitie”In Chinese pinyin, meaning "you answer my published articles." 😀 😀
The latest process.
Today's test results.
The results are satisfactory.
Hi
thats mean you are so kind,
pls send me pm
how much shipping cost to jakarta indonesia
(if you can pls use registered post)
is this include the pre board?
i want ask u
how big the heatsink for your PCB
in the Krell ksa50 mk2 PCB some friend use
Conrad Heatsink lenght 30cm height 15 cm
but he run bias 1,5A if more than that (1,9A) was like toaster
so he set up back the bias to 1,5A
Hi
pls send me pm
i want ask u
Hi
1.Yes, send EMS to you?
2.Now that the PCB, not including the preamplifier, Preamplifier PCB10 days after the make.
3.Heat sink size is based on your use of the quiescent current to decide.
Hi
1. i think ems is ok, they are not weight enough
2. ok then for the pre amp
3. for your design how much current need to produce 50w output
btw gxcnabin can you give us list of BOM (Build of material)
to look the small character on the schematic is to tired for the old eyes
For 50W class A for 8 ohm load using 2 pairs you will need 883ma PER device.
That calculates to 1.77A per voltage rail idling.
for 0.47ohm resistor like on this pc board that calculates to 415mV voltage drop over resistor.
your heatsink will have to be around 0.2 C/W per channel. BIG!!!
(hope i did those calculations correct?)
gxcabin , how much for posting 2 boards to South africa?
I am amped about this design, hehe
