or really lucky = Love Room 😉
Edit: Here's a write up on using one as an air pressure pump for paint spray: http://www.volksrods.com/id36.htm
Yeah, keep the old oil in the compressor, use an oil filter/trap at the output. They sell them for painting. Harbor Freight probably has them cheap.
Dunno how long that will prolong the life...
_-_-bear
_-_-bear
I am using 2 aquarium pumps in parallel, each one rated at 1.75psi and 800l/h.
The air requirement here is more about volume than pressure - as the pressure rises the noise from the manifold rises too. Lots of flow at lower pressure is the way to go. That kinda eliminates using a tank I think (have I got that right?).
On pump noise. This is really worth finding a good solution for. I tried a fair amount of things to quieten the pumps I am using. I damped their enclosures. I added an expansion chamber. I tried turning them down and up. No matter what cupboard I put them in they were still audible (annoyingly so). Eventually I put them into one of those alu tool boxes (you know the ones that photographers use for equipment). Its foam lined and I have that in an adjoining room and run a pipe to the arm from there. Not an ideal solution maybe, but it works.
I think for anyone about to build one of these things, the aquarium pump route is a very realistic way to go, but you will need to site it in another room.
Other than that one point, this arm is a great performer and will be a keeper for me. I need to go back and refit one or 2 parts to optimise it a bit more, but at least I now know its well worth it.
Fran
Fran
moving mass... in a good way...
really, is there any other way?
bear, if the freedom exists to build something, to me, it just makes sense to reduce any moving mass as much as possible. Then make sure you have enough counterweight to offset the cartridge mass.
I guess I assume some common sense and some idea of Inertia is known so that folks can participate in, what really is in effect, a physics problem.(and bear this is not a dig at you, as I am confident that you understand, but perhaps some others may not... and that is not a dig at any, just trying to clarify as much as possible for all.)
Kinda like racing cars---reducing the unsprung weight has a profound effect on how the complete suspension acts and responds to road conditions. Reduce the sprung weight and those effects will be greater...
ah..cars n' tonearms...2 great hobbies. (Ok and motorbikes too)
stew
stew
pump noise....
a buddy of mine was working for a time spraying a very nasty two part epoxy paint which required a full fatial mask with air. The vibration of the air pump was driving him crazy. So he tried to add in line foam filters to smooth things out. In the end he built a muffler iside of a length of plastic pipe. The muffler had staggered baffles with foam also filling the cavity. The muffler was what smoothed things out as far as him feeling vibration on his face. So if you can feel it you can hear it and it will impact your tonearm as well. Hope that this is helpful in making things work a little better.
OK, TransFi - the "official" Terminator arm site mentions two suitable air pumps:
- Sera 550 pump: max 550 L/Hr @ 150 mbar (2 psi),
adjustable flow control Note: no noise rating
- Rena 400 air: Max 133*2 L/Hr @ 4.5 psi (310 mbar)
adjustable flow control Note: <30db noise
Frans (2 parallel) pump is rated at 800*2 L/hr @ 1.7 psi (117 mbar). I presume this wouldn't run reliably on 1 pump & yet this would give an airflow of 400 L/Hr - I guess the pressure that this is delivered at is important also
Quote from Sera manual:
Every diaphragm pump produces an audible vibration & hum noise. This can be minimised by providing a counter pressure. A hose clamp or regulator valve that reduces airflow also considerably reduces the noise.
What cartridge can i use?
Is the any difference in the calculations from the Compliance?
I m planing to use the Sumiko Blue Point Special Evo III in a terminator style tone arm.
Is there some kind of rule that i can use to find out what is the right cartridge for this arm.
Regards George
Regards George
Another take on this...
I read through this thread and found a lot of interesting information. I studied the Terminator air-bearing linear-tracking tonearm and have been tinkering with the idea of building one myself. Then I stumbled across this inexpensive air-bearing linear-tracking tonearm and recalled the above quoted post.
This got me thinking in another direction. Using aluminum pipe and tube and epoxy adhesives I came up with this (very) rough sketch. Carbon fiber is another idea.
The arm would slide along the length and pivot around the axis of the tube. The second larger sleeve would be drilled to allow the arm to be bonded to the "slider". Obviously this design would put the tube fairly close to the record surface so the arm itself would probably need to be long enoug to clear the radius of an LP.
Any problems inherent in this design stand out? Comments?
Martin
Nanook said:couldn't something like this be done to underhang a "tube" style air bearing?
Martin
Fairly cheap pump
For those in the US. I just found a fairly decent deal at petco. The ac9904 pump outputs 9L/min at 2psi, ad costs 24.99. Not to loud and it has variable output
DIY FOREVER!
Here's DIY air-bearing tonearrm in a post from HiFiForum, including many great pictures:
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=61202 In Swedish, original post
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=61202 In English, Google Translate
Mounted on the underrated classic, JVC QL-7 direct-drive turntable.
Very interesting - also considering the original is norwegian - not swedish!
Norgies have this strange thing about swedes....😀
< ducking >
< ducking >
Just curious, how do one drill 0.3mm holes in the tube?
Easy, with a 0.3mm drill bit
You can use a PCB drilling machine or a drill Proxxon unit
I managed to drill seven holes with a drill so bring plenty of drills.
Regards George
Depends on material
Brass would make it easier to drill
But just about anything today is cut by using lazer or water
But such arm has a small flaw
And thats all the holes outside the arm console
And that dammed noisy air pump
But it sure is a fine arm to use, and simply magical to the music
Hard to believe this is a DIY project!
air bearing tonearm from China with specs
00. http://www.records33.com/Gimg/20102114429349.jpg
01. http://www.records33.com/Gimg/201021144213898.jpg
02. http://www.records33.com/Gimg/20091117114423343.jpg
03. http://www.records33.com/Gimg/2009111711314150.jpg
04. http://www.records33.com/Gimg/200911171135736.jpg
05. http://www.records33.com/Gimg/2009111792628247.jpg
06. http://www.records33.com/Gimg/2009111792632735.jpg
07. http://www.records33.com/Gimg/2009111710352184.jpg
08. http://www.records33.com/Gimg/2009111792637397.jpg
09. http://www.records33.com/Gimg/200911171236995.jp9
10. http://www.records33.com/Gimg/2009111701826283.jpg
11. http://www.records33.com/Gimg/20091117142335639.jpg
12. http://www.records33.com/Gimg/20091117112512625.jpg
13. http://www.records33.com/Gimg/20091117153135250.jpg
14. http://www.records33.com/Gimg/200911162314776.jpg
15. http://www.records33.com/Gimg/2009111623127252.jpg
16. http://www.records33.com/Gimg/20091117101834364.jpg
17. http://www.records33.com/Gimg/20091117101834364.jpg
18. http://www.records33.com/Gimg/20091116234017512.jpg
19. http://www.records33.com/Gimg/20091116223130969.jpg
20. http://www.records33.com/Gimg/20091117161736891.jpg
21. http://www.records33.com/Gimg/200911170621587.jpg
22. http://www.records33.com/Gimg/20091117151940648.jpg
23. http://www.records33.com/Gimg/2009111622451535.jpg
24. http://www.records33.com/Gimg/20091116222211144.jpg
25. http://www.records33.com/Gimg/20091116231852953.jpg
26. http://www.records33.com/Gimg/20091117112528451.jpg
27. http://www.records33.com/Gimg/20091117112539962.jpg
28. http://www.records33.com/Gimg/20091117112951428.jpg
29. http://www.records33.com/Gimg/2009115135429857.jpg
30. http://www.records33.com/Gimg/2009122161216582.jpg
31. http://www.records33.com/Gimg/20091130114210950.jpg
32. http://www.records33.com/Gimg/20091130105043573.jpg
33. http://www.records33.com/Gimg/201011322817108.gif
Well,
to put it mildly, that's impressive!
poking around his web site, I found some more pictures of this arm.
Here is a link to some sort of user manual
Regards George
Any recommendation on drilling speed for different materials: brass, steel, aluminum?
With these small drills, it does not really matter how fast your machine turnsAny recommendation on drilling speed for different materials: brass, steel, aluminum?
Approximately 20,000 RPM is enough to drill well in all materials
Use a cooling / lubricating fluid otherwise the drill break too fast.
Greetings George
Here is Trutium air tonarm TT on e-bay. From the pictures it does look that holes are bigger than 0.3mm:
TRITIUM AIR BEARING BRASS PHONO TURNTABLE RECORD PLAYER - eBay (item 150273127372 end time Jun-09-10 11:57:22 PDT)
YouTube - TRITIUM AIR BEARING ULTIMATE TONE ARM TONEARM TRIPHAZER TURNTABLE DEMO
It does look very much DIY-like.
- Analogue Source
- DIY Air bearing tangent tone arm
