100W Ultimate Fidelity Amplifier
Ultimate Fidelity with more power.
in fact i want to use a 35 Ampere bridge rectifier and it doesnt fit, the 8A bridge you suggest may not be adequate enough and will propably get quite hot so i think of not using the short circuit protection and not place any of its components ,and in that space i put the biggest bridge rectifier .
i have placed all the components so far and i will continue tommorow..
You can put bridge rectifier out of pcb, and connect it with wires,
here is the psu ,but without the overcurrent protection parts.ithis space i want to put the 35Α bridge rectifier
Put the 35A bridge rectifier on case and connect with wires from pcb. Overcurrent protection is very adventage circuit and I suggest to use it, this short circuit protect cut out speakers even at low volume level, you can use amplifier without rail fuses and VI limiter with this protect safely.
this is the best i can get with my phone camera .its night here now.
i havent tested the psu yet.i will connect the 35A rectifier and put back the short circuit protection.
do you suggest 0.22ohm resistors for short circuit protection ? i am using a 24-0-24 volt /200VA transformer which is +-33 volt dc after rectification and smoothing capacitors.
