Don't worry about power resistor heat, useing with music signal disipate is not that high.The gap can not increase, the details abut
i'll go for mic pre amp with tone controlAmplifier don't have any tone controls, just have pot for volume control.
If you want to use mic preamp with tone control, equaliser or active x-over for sub-sut operate, that is separate modul, I can share some of this circuits in new thread "Active x-overs" if you want.
Profi look with bias transisror on wire.I finished collecting b500, here's what I got! "A few days ago will be tested.
You can use some mixer.i'll go for mic pre amp with tone control
What is rail voltage?Hello, passed the first test, the sound I liked
The amplifier worked at a voltage of +-85B, take food from the neighboring amplifier that photo.What is rail voltage?
With this rail voltage heatsink must be larger, but ok for test. PCB is small, but this is powerfull amplifier.Power suffered at the voltage +-85B, take food from the neighboring amplifier that photo.
What speaker you use for the test? PA or Hi-Fi?The amplifier worked at a voltage of +-85B, take food from the neighboring amplifier that photo.
like some commercial amp i want an amp with pre amp tone control in one🙂You can use some mixer.
Hello, As the load used is that the photoWhat speaker you use for the test? PA or Hi-Fi?
[url=http://www.magnet.com.ua/loudspeakers/M112.html]
What about crossover?
I asked becouse this amplifier have Hi-Fi sound, better than many "Hi-Fi" amps.What speaker you use for the test? PA or Hi-Fi?
Use two 12V 20W bulbs in series on input of HF crossover.Do you have a protection scheme?
Commercial amp with tone control are Hi-Fi integrated amplifiers usualy 2x80W output power.like some commercial amp i want an amp with pre amp tone control in one🙂
- 500W PA amplifier with Limiter
